T-5 tran. i think
Old Oct 18, 2001 | 12:23 PM
InDa12's's Avatar
T-5 tran. i think
i just went to a jy and found a 89 camaro v6 with a manual tran. i think its a t-5 but i don't know, i have heard that the t-5 can bolt to a 350(l05) is it true can it?i have the 700r4 right now and i don't like it.another question is will the driveshaft be long enough or will i have to take the drive shaft from the t-5, and will bolt up to my rear end? please help i need to know soon so i can get it.
Old Oct 18, 2001 | 12:33 PM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
yes it should bolt up to it as long as its a 3.8 v6, i know the 90 degree 6's have the same bolt pattern in back, but the 2.8s have a smaller pattern, hope this helps ya
--Stormr
"If its in my way-It gets run over"
--'91 firebird
305 TBI
Hypertech chip-thermomaster
Edelbrock performer intake
Crane compucam 2031
B&M shift kit
straight pipe exhaust-with Flowtech resonator tips
160 thermostat
open element
Old Oct 18, 2001 | 03:00 PM
CODY BEHNKE's Avatar
If it's an 89 it will have a 2.8, so you'll have to find a V-8 bell housing.
1991 Formula WS6
305 LO3 TBI 5-Speed 49,000 miles SLP Cat-Back
Hypertech Chip, etc....
Old Oct 18, 2001 | 11:39 PM
Keith5's Avatar
Car: C1500
Save yourself some trouble, find a v8 T-5. A T-5 uses the same driveshaft as the 700R4.
1989 Pontiac Firebird Formula LO3/700R4
-180 degree stat, Hooker Cat-Back, Wonder Bar
http://www.geocities.com/krt80/
Old Oct 18, 2001 | 11:57 PM
Tas's Avatar
Tas
you would at least need the v8 bellhousing so you can bolt it to the v8. You would also need the v6 driveshaft because the splines on the tailshaft are different.
-Tas
'89 Formula WS.6
Got Beach?
Old Oct 19, 2001 | 02:07 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The splines on the input shaft are different too. Dont even bother with a V6 transmission on a V8 engine. Just find a V8 transmission.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 19, 2001 | 06:30 PM
DM91RS's Avatar
Car: 91 RS
I second Kevin. A V6 T-5 has a lower torque rating. They also have wider gear spreads than the V8 one's.
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
