1990 Caprice 350 TBI?
I was able to locate a 1990 police package Caprice with a 350TBI. Would this be a roller cam motor and how could I tell without removing the intake? What else would I need off of the car to swap it into a 1991 Camaro RS 305TBI without running into any major problems?
Car: 92 & 93 caprice 9c1's
Engine: L05's
Transmission: 4L60's
Axle/Gears: 3.42's one G80, one open
Re: 1990 Caprice 350 TBI?
Yes it will be a roller cam motor if its the same one the car came with. I dont think there is anyway to tell if it actually has a roller cam unless you tear it down. Read the sticky about 305 to 350 swap at the top o fthe page, it will tell you everything you need.
Car: 1991 Camaro RS
Engine: 305 TBI
You will need the ESC and the knock sensor for a 350 TBI. The cop car injectors will be a help as well. You will also need a new chip. I have been researching this swap as well. Keep me posted on how it works if you pursue it.
Check out the sticky at the top of this forum. It has a lot of info on this swap.
Eric-86sc
Aug 24, 2015 09:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
