Please help, code 32
Old Apr 28, 2007 | 08:55 AM
rebel1222's Avatar
Car: Looking
Will it help to take your egr valve off and clean it?
I continue to get a code 32. I replaced the EGR seleniod because the old one was broken, but I still get the code. Since they want $50 for a new egr valve at autozone, will it help to clean my old one up real good and see if it fixes the problem before buying a new one? I also get the surging in gear while idling. Would this indicate that the egr vavle is not closing at idle?
I replacd a 305 with a 350 a couple months ago. Other than this, she's running good.
Thanks in advance for your input.
Old Apr 30, 2007 | 09:38 AM
rebel1222's Avatar
Car: Looking
Re: Please help, code 32
No one willing to share their thoghts on this?
Old May 1, 2007 | 02:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Code 32 on a TBI is a very common problem because of the way the EGR valve operates. Did you do a search here to see how others have solved their problem?
Old May 1, 2007 | 02:02 PM
rebel1222's Avatar
Car: Looking
Yes, I searched, but I couldn't find any clear resolutions. Can you take it off and clean it? Thanks for your reply.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
