Can I run 8 MPFI injectors with a 7747?
Please help! I thought they were Magnetti Marelli Injectors but now I think they may be Webers???? Funky "W" on them.
16 ohms resitance, so they must be OF THE "saturated" type. Can I use 8 of these with the 2 Peak and Hold drivers of the 7747 ecu? Will P+H drivers mess them up as they are saturated-use injectors? Soooo many questions.
[This message has been edited by fast_broker (edited October 22, 2001).]
I'm curious as to why you want to use the 7747. Kinda like using a pliers to pound in a nail.
The 7730 is a no brainer to run 8 saturated injectors. It also has the proper batch firing scheme.
Because I got one and use several on other vehicles/motors I own or test on. a 7747 PRocessor is plenty fast, it's the data stream that sucks...
Need/want to use a 7747... HELP??? I need answers??!!
That won't be a problem. The problem is that I am not using the injetors they are using, which I now believe are P+H's. They are MUCH smaller (ie shorter, not as fat) than the ones I got...
Yeah, they are Pico injectors. What the heck does that mean, anyway???
Are they P+H or SATURATED??? Gotta be saturated with 16 ohms of resistance, I guess...
I would assume that the P+H drivers wouldn't work with these injectors BUT since you are using too many injectors, maybe the injectors feel like they are getting a saturated-type input and will work ok???
HELP, GhoSST?!?!?!??!?!?!
[This message has been edited by fast_broker (edited October 23, 2001).]
Why are they so big in the body area????
I mainly wonder if I buy a Weaind MPFI-ready manifold for Vortec heads and their associated rail/regulator kit, WILL THESE PICO INJECTORS INSTALL CORRECTLY????????
The ones I have are off my Edelbrock ProFlo RPM system. FAT mothers. Look in a Summit catalog at the ProFlo RPM picture. You'll see how fat they are. Maybe no bigger than the Holley injectors, though... They have a tapered rubber tip thingy on them, too, which is odd. O-ring, too, of course.
fast-broker check this out if you haven't already. https://www.thirdgen.org/messgboard/...ML/000086.html You might need a MegaSquirt
The pro flow uses traditional injectors on a Victor type intake. The edelbrock multi port conversion for TBI vehicles uses pico injectors on a torker2 type intake.
https://www.thirdgen.org/messgboard/...ML/000429.html
[This message has been edited by Tas (edited October 25, 2001).]
Aaah. So mine ARE NOT Pico injectors... I thought I read somewhere that they were... oops. Mine look like the big ones in your pix but there is a tapered rubber piece (seat?) below the bottom O-ring.
Anyway, I wonder if the Picos and the big ones have the same electrical characteristics, ie, current/pulse width needs/resistance/etc????????
I have yet to call in my favors from Edelbrok. Getting close, though...
