width of wheels?
Old Oct 27, 2001 | 09:57 PM
Tas's Avatar
Tas
width of wheels?
Will 17x11 cause excessive understeer or will the added traction be worth it? Should the fronts and rears be the same width (all 17x9.5)? I think I'm gonna get these boyds.
I put this on the autocross board too but by the looks of the dates on the posts, its pretty dead over there.
-Tas
'89 Formula WS.6
[This message has been edited by Tas (edited October 27, 2001).]
Old Oct 29, 2001 | 12:08 AM
Andy89RS's Avatar
It really depends on your suspension setup and your weight balance. My car is light in the back due to removed spare/jack and no rear seats. This gives me some understeer. Once I relocate the battery to the back and tune the suspension some more I should be able to get it more neutral... Unless you're planning on taking your car to the track like me don't worry about it. Your overall traction should be higher and between understeer and oversteer, under is the more easily managed of the two.
Old Oct 29, 2001 | 09:48 AM
NTChrist's Avatar
Ooo! Sidepipes!
No guts, no glory.
Old Oct 29, 2001 | 03:35 PM
IrocJT's Avatar
Sweet side pipes!
I want to do that, especially if there are 2 more on the other side! (although I don't really think that there are.)
1990 Iroc
Canadian Iroc (305 TBI)
-14x3 open element, K&N
-Accel: Coil, Wires, Cap&Rotor
-B&M stage 2 shift Kit
- 4 255/50/ZR16 BFGoodrich Comp TA's
-Hypertech chip, low temp thermostat and fan switch
-1.6 ratio roller rockers
-3" exuast: High flow cat, meanstreak muffler, dual 2.5" outlets
-Holley projection Manifold
-670 Holley TBI.
Old Oct 29, 2001 | 03:42 PM
Tas's Avatar
Tas
Its CarNDrvr's car do a name search on "CarNDrvr".
-Tas
'89 Formula WS.6
Old Oct 29, 2001 | 04:19 PM
NJ SPEEDER's Avatar
the suspension is thirdgens and fourth gens for that matter is very well balanced when it comes to the equality of front to rear grip. that means that running a larger rear wheel wil tend to create more rear grip and cause the car to understeer.
the only way you can really get away with this and use it to your advantage is if you have aenough power and knowledge to "steer by throttle", that is to use rear wheel spin to help the car rotate. i can tell you from my own road race/auto-x experiences that it is a hard thing to larn and not often the fastest way around, it is however a hell of a lot fo fun once you learn how to do it.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Oct 29, 2001 | 09:06 PM
Chad91Rs's Avatar
Understeer is not a problem for me with my setup.
17x11" in back with 315/35/17 and 17x8" with 235/45/17 in the front.
Like Andy I have ALL things unimportant gone (carpet, stereo, seats, emissions) and my battery moved to the rear with larger sway bars , a wonder bar, and a tower brace so if anything I get some oversteer around some uneven streets just because my suspension is so damn hard.
Old Oct 29, 2001 | 10:09 PM
NJ SPEEDER's Avatar
are we talking about real performance driving or street driving? street driving is completely different. you will never see the limits of a car on the street.
later
tim
Old Oct 29, 2001 | 11:25 PM
IrocJT's Avatar
what is the widest rear tire you can fit without rubbing?
1990 Iroc
-670 Holley TBI.
Old Oct 29, 2001 | 11:45 PM
My305camaro's Avatar
If you go with the factory 16in rim, and go with matching tire sizes in all the corners, it is 255/50/16's. This keeps the 26in diameter of the stock wheel, and only rubs slightly at full lockout in the front.
1991 Chevy Camaro RS TBI w/auto
Mods:
Edelbrock TES Headers, REALLY high flow cat, 2 1/2 in catback flowmaster, 160 stat, hypertech chip, MSD ignition (rotor, cap, superconduct. wires), Bosch quad4 plugs, Ram Air Box twin snorkel, all TBI mods, no smog stuff, no EGR, lots of suspention and alignment upgrades, and a big Chevy bowtie sticker on the back.
Fastest e.t.:
15.42 @ 88.19mph
Fastest 60 foot:
2.113
okfoz
Sep 17, 2015 10:30 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
