How much of an increase do the Ultimate TBI mods really make? I don't mean the non-drop air cleaner, how much will all the customizing on the TBI make? 10, 15 hp? I'm considering doing this over the winter, if it's worth the work.
Thanks!
1992 RS
327, Modded TBI, Rebuilt WC T-5 5-speed, PRO 4 15" rims, Nitto's, 3.73's, SLP 1 5/8" headers, and a few other things.
Thanks!
1992 RS
I dont think anyone has dynoed a before and after
the best dyno is the track though and i know a few people have done before and afters
why not do a before and after and let us know? it only takes a short amount of time to do it
yes, be the first for us.
But, i think we can all say for a fact, that it doesnt hurt anything, and anything that helps a little is worth it.
Hey and look at it this way, you get to play with a dremel, and anything with any sort of powertools is fun.
I guess I'll have to try it then. I've been looking at the TBI unit and have come up with a few more mods. If they help out, then I'll post them on my website, but that won't be until spring obviously with all the tracks closed. Thanks guys.
BTW, how high should you raise the injector pod? How many gaskets is it?
1992 RS
1992 RS
from what Ive been told.
it depends on your injectors.
just raise it until the spray hits like a 1/16 of an inch above the blades.
i think its just one other injector spacer.
dont quote me though
I read the ultimate TBI, but cannot find it. could someone tell me how to find it or e mail it to me. stock 91rs 305 TBI looking for any cheap mods or free mods.
www.cfm-tech.com has all your tbi needs, the guy is awsome
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
I like the air powered disc grinder myself. I used that to rip the ridges off the bores and radius the edges. After that it was all dremel and Mothers polishing compound.
http://communities.msn.com/V8AstroCa...astromods.msnw
You can see the FMGasket picture. This is where I made a "spacer" by RTV-ing two fuel metering gaskets to each other, instead of buying a phenolic spacer for $30.
be aware that you can see my Mustang in one of those pictures! Just wanted to warn you since this is an F-Body site
'92 Astro, GM crate 350, Performer TBI intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
[This message has been edited by V8Astro Captain (edited October 29, 2001).]
