I'll get it running tonight if I get help with timing
Old Oct 15, 2001 | 08:41 PM
91RS5.7TBI's Avatar
Ok, when it says in the chiltons manual to ground terminals a and b in the aldl to adjust the timing, does that mean ground both of them or ground a to b, since a is supposed to be a ground?
Old Oct 15, 2001 | 08:56 PM
firbird's Avatar
are you sure they say that? because i just set mine by discondecting the est wire next to the ac under the hood
Old Oct 15, 2001 | 09:20 PM
Faithbird88's Avatar
What year is your car, If you have a earlier Thirdgen say 82-85 timing will be differnt, if you have a 86-92, you have one wire connection which must be disconnected before and timing is performed, then once you have set the timing shut the car off and reconnect the wire, and check the timing again, you should be 0 degrees Before Top Dead center (BTDC) if you automatic tranny you will have to have somone put it in drive and hold the brake, if you manual you can just time it at idle speed and without being in gear...any other question email me at Londonaftermid21@aol.com
Old Oct 30, 2001 | 11:47 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
not to mention that chiltons manuals are notorious for making mistakes andgiving wrong info
--Stormr
"If its in my way-It gets run over"
--'91 firebird
305 TBI
Hypertech chip-thermomaster
Edelbrock performer intake
Crane compucam 2031
B&M shift kit
straight pipe exhaust-with Flowtech resonator tips
160 thermostat
open element
Old Oct 30, 2001 | 01:05 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
1 Turn the car off and disconnect the EST wire
2 restart the car and it will run a little rough and throw a code (don't worry) put your light on it and set you BASE TIMING.
3 Turn the car off and then replace the EST connector and if you want to clear the code then remove the + side of the battery for a few minutes.
4 you should be on your way.....
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Oct 30, 2001 | 04:17 PM
92Camaro305TBI's Avatar
Brian Felts?
What times are you running? Seems like a nice setup!
92 Camaro 305 TBI Automatic
https://www.thirdgen.org/rides/index...ew&rideid=6100
Old Oct 30, 2001 | 04:25 PM
JPrevost's Avatar
Car: 91 Red Sled
Brian hasn't gotten to the track yet. We should be going some time soon to an 1/8 mile this winter. It's running dog rich (108 BLM pegged) but it pulls hard enough to plant you into the seat pretty good.
His method of setting base timing is exactly how you're suposed to do it.
As for grounding the a and b terminals on the aldl....that's to set min idle!
Do this, wait a little while until you see that the stepper motor (your IAC) plugger is all the way out (no vacuum leak) then unplug it. Turn off the car, take out the a to b paperclip, turn the car on and adjust min idle to about 500-600 for a stock Lo3 with minor bolt ons. Turn off the car, plug the IAC back in, turn the car on. It should idle pretty high and then come down, just wait and it will. You might have to adjust base timing and min idle back and forth because both are needed for a good idle that doesn't stall when put in gear etc.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
justin57
Aug 20, 2015 07:05 PM
