Engine Rotates but doesnt start
Old Oct 30, 2001 | 10:09 PM
Faithbird88's Avatar
i just finished installing the intake gaskets, and a timing chain, i aligned the 2 dots on the Timing sprokets perfectly, but i cant get my car to start up, bascially it cranks and cranks, and puffs of white smoke shoots out the the Throttle body bores, i think i might be lacking spark, i've removed my distributor, i also thougth i was 180 degrees out on the distributor, i rotated about 7 times i'd say still no luck, it seems to crank better now but still doesnt start up, does anyone have any idea what im overlooking or what could be wrong, if any has the answer or some troubleshoots that might be helpful, e-mail me at Londonaftermid21@aol.com
thanks, mike
Old Oct 30, 2001 | 10:42 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Did you check the timing? Even though the timing chain sprockets line up you could be waaaaaay out of time. Thats the only reason that I could think of for why its shooting out white smoke...
-=-Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Oct 31, 2001 | 08:23 PM
well guys i took some of my bosses advice at work today, he gave me some pointers, so what i found out is my car was trying to fire on the intake stroke of cylinder #1, and my distributor was completely firing the wrong cylinder so all i had to do is make sure my valves on Cyl #1 were closed on the compression stroke to 0 degrees TDC then rotate the Distributor so that the rotor point is aimed at the #1 Cyl terminal, then she fired right up, and then just needed a fine tuning Timing wise, thanks again guys,
mike
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
