Big Question TBI to TPI
Old Nov 1, 2001 | 09:46 PM
89 4Mula 350 Tbi's Avatar
Guys i found a person selling an entire tpi setup for 400 dollars harness comp and intake everything i'm interresded in getting it but how hard is it to run the harness excetera.
Old Nov 1, 2001 | 10:06 PM
Tas's Avatar
Tas
That thing will choke your 350. It is a great price though.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 2, 2001 | 12:09 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
TPI = pain in the a$$.
I like TBI better even tho some says it's not performance. No....it wasn't DESIGNED to be performance. But I'll betcha TBI will flow better on a 350 b/c TPI was designed for a 305 below 4500 RPM.
But hey, if you want to deal 4,000,000 half-stripped T-45 torx bolts and horrendously expensive performance parts, you have more patience than me!
Old Nov 2, 2001 | 09:23 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Are you guys serious? I switched and my 350 isn't "choked." Bottom line is: if you want some performance go TPI. simplicity? well you know.......
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 2, 2001 | 09:34 AM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">Originally posted by GofasterFirebird:
</font>
Um, no. Are you running 100% stock TPI and running 13.5? Shane B had a $95 Carb intake under his TBI 350 with vortec heads and ran the same thing and lower if his trans wasn't slipping. $400 TPI and hassle of chaning over vs. $95 carb intake. hmm...
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
[This message has been edited by Tas (edited November 02, 2001).]
Old Nov 2, 2001 | 04:39 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Nothing like goimg BACKWARDS huh?
Old Nov 2, 2001 | 05:08 PM
JPrevost's Avatar
Car: 91 Red Sled
Buy it, sell it for more.
Old Nov 4, 2001 | 10:34 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by 89 4Mula 350 Tbi:
Guys i found a person selling an entire tpi setup for 400 dollars harness comp and intake everything i'm interresded in getting it but how hard is it to run the harness excetera.</font>
It's not that hard, but time consuming.
If it's a 90-92 set up, that is a great price. If it's a 85-89, then your going to fall subject to the MAF stuff.
If your thinking about going quick, the later setup is the way to go.
If you go to the Prom burning section, and look at the *final answer* threads there might be some info., that would help you figure out what exactly is going on.
Old Nov 6, 2001 | 11:16 PM
Car: 1991 Firebird
Engine: 427 LSX
everyone has a buddy that has a faster car. I really respect people that can bolt on a carb. really
get 20 plus mpg, cold start up perfection, and 13.5 seconds, and then we will talk.
1991 Firebird
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
