What oil pressure does your LO3 run on?
Old Nov 11, 2001 | 05:38 PM
Brad91Rs's Avatar
Car: 1991 RS and 1998 Trans Am
Engine: 6.0L(lq4) & 5.7L(ls1)
Transmission: 4L60e
Axle/Gears: 323
Mine used to run above the line between 30 and 60 (45 or more). Ever since I got the new gears and rear end the oil pressure is around 35 is this normal or is something going on w/ my car? BTW my car has about 168,000 on the stock engine w/ only the mods in my sig. Thanks for the help.
Brad
91 metallic blue RS Flowmaster exhaust, Eibach Sportline Springs, KYB shocks, Open element, 323 posi rear w/ rear discs. TPI conversion soon.
Old Nov 11, 2001 | 07:09 PM
jase's Avatar
That seems to be normal.Mine runs between 35 to 40.
Old Nov 11, 2001 | 07:16 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm not the F-body expert but I have been driving my brothers '85 IROC for the last week. It runs about where you said yours does.
45-60 when cold. About 30 when warm.
'92 Astro, GM crate 350, Holley Pro-Jection Intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Nov 11, 2001 | 07:18 PM
NJ SPEEDER's Avatar
that is around where mine runs when i use 10w30. if you use a lighter weight oil it will make the pressure go down a bit, when i use mobil1 0w30 it can get as low as 20, which is still safe.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Nov 11, 2001 | 07:30 PM
BahamutRS's Avatar
At idle it usually runs at about 25...then when I'm cruising it can jump past 50, usually wades around 45 though.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K&N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Old Nov 12, 2001 | 03:16 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
Thanks for the help, with 168,000 on my car I get kinda paraniod that something will go wrong. What can I say, I love my car too much
Brad
Old Nov 12, 2001 | 10:56 PM
BahamutRS's Avatar
That many miles? Consider a 350 crate, my friend
Old Nov 13, 2001 | 05:29 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
I'm getting an LS1 Fbody this spring, then later on I plan on replacing the 305 in my RS w/ a superram 383 with all the trimmings. However for the meantime I just have to stick with the old L03, which has never had any problems (besides beings slow )
Brad
Old Nov 14, 2001 | 10:09 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
That's not bad pressure for a high mileage motor.As a matter of fact,it's
about the same as my 305 with 225,000 miles.
Just replaced mine with crate 350, but it still ran good and didn't burn more than a pint in 3500 miles,when I swapped it out.Just didn't want to wait until it died to replace it.Might freshen it up and put it in my S10 Blazer!
-Rich-
Old Nov 14, 2001 | 10:17 AM
chevySS's Avatar
Mine usually runs about 50-55 when its cold, and when I am driving on the highway at normal speeds. But usually when I stop or when I am driving slow like in town, it runs about 25-30.
Teal Green 91 Camaro RS
305, Automatic Tranny
Stock for now
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
