Would a stage two chip help much?
Old Nov 14, 2001 | 12:11 PM
dmair5_0's Avatar
Car: 91 Firebird
I know that this should probably go under the PROM board but I wanted to know from you TBI experts! I have a LO3 firebird and am thinking about getting a chip, the stage two kind for "off road use only" ha. Anyway, have any of you put this chip on or a similar one? Did you notice a difference, any dyno runs? I guess I'm asking if it's worth it. I would be adding it to my car along with an open element, edelbrock tbi manifold and a 160* stat. Good idea? Thanks for the help guys!
Old Nov 14, 2001 | 12:37 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I think if you can spend the money, a custom chip is well worth the trouble.
Most I've spoken to don't have a very high opinion of the generic "stage 2" chips regardless of manufacturer.
I have a custom chip from Fastchip,and am very happy with the performance.Don't honestly know how much better this is than the others, but Ed Wright guarantees nobody's GM chips are faster than his.There are several guys that post regularly on this site that can also burn you a custom chip,though I have no experience with them personally.
I'm sure others will be able to give you a more specific answer to your question, with real before & after numbers,et's etc.
-Rich-
Old Nov 14, 2001 | 12:41 PM
dmair5_0's Avatar
Car: 91 Firebird
I know a custom chip is a great improvement, but do I really need one with the mods I have? Besides what I listed, I have a 3" Dynomax exhaust, B&M Shift Kit, and a Cold air induction, along with the ultimate TBI mods on this site. Thanks again!
Old Nov 14, 2001 | 01:19 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
no .. you really dont need a custom chip until you start getting into cam /intake/head work.. but unless you can get one really cheap.. paid 40 for my jet stage 2... its not really worth what they would charge you for a new one. your better off using that money for something else right now.
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets,posi 323 , lt1 cam and new valve springs
Old Nov 14, 2001 | 01:56 PM
JPrevost's Avatar
Car: 91 Red Sled
excuse me but did somebody say off the shelf eprom...i hope NOT! Never, it's been said hmmm...too many times. No off the shelf eprom is going to help.
What you could do is hookup a scanner and see if you're running lean (BLM will be below 128 for normal driving, NOT under WOT because it defaults to 128). If that's the case, increase fuel pressure slightly. All better now :-D until you can afford more mods I wouldn't pay more than $10 for an off the shelf "chip" no matter what stage it is.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
