Weird..
Old May 11, 2007 | 09:49 AM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Weird..
Car runs awesome when it is Hot. However, when it is cold, it pulls away ok, stop at the first stop sign I come to and the tach drops to about 300 car shakes a little, and hen corrects and jumps to around 900 and also hesitates when giving the gas it sputters unless i give it more gas, does this for about 10mintues, then when its warm, all is great,r uns flawless! Any sensor that controls cold operation?
Chanegd MAT sensor and Fuel Filter... I am getting code 32 (egr) but wouldnt that effect it when its hot? I do feel light surging on hwy, which is egr, and I know that, but whats causing my cold weather operation?
Any ideas?
Old May 11, 2007 | 01:25 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Weird..
soundsl ike coolant temp sensor.
Old May 11, 2007 | 01:56 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Re: Weird..
Yah? Would it give a code? What would it cause?
Old May 11, 2007 | 02:56 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Weird..
ya you wold think it would give a code..usually when they are bad the car runs rough when cold and heistates and doesnt wanna move. it's located on the intake by the thermostat.
Old May 12, 2007 | 06:28 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Re: Weird..
Still does it... Only when its cold, it will almost stall at a light (never DOES stall, but stumbles then catches itself) and if u give it gas it sputters.. untill its warm? Any ideaS?
Old May 13, 2007 | 06:22 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Weird..
u said still does it...does that mean you replaced the coolant temp sensor? sometimes the conector is bad too..you might have to have a shop look at it
Old May 14, 2007 | 08:43 AM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Re: Weird..
Cars timing was 4* retarded! (had a guy check it, said it was ok
Set it to 4.5 * advance... went to a big parking lot to.. see how it ran
Whatcha think for a lil ol' L03.
Click here to watch Burnout-45
IlikeIroc
Mar 8, 2015 04:19 PM
bigjcfiredog
Aug 16, 2014 03:03 PM
98t595
Jun 1, 2011 08:29 PM
DeathStarr89
May 22, 2011 11:34 PM
