Loud bang when accelerating
Old Nov 26, 2001 | 10:24 AM
dtpmike's Avatar
When I am at a stop and press it WOT usually it feels/sounds like a bang then it goes, it only bangs from a stop I think. Could this be a bad transmission mount?
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock TES Headers, Exhaust cutout, Edlebrock open element, 160 degree T-stat, Hurst Dual Gate shifter, Lakeland LCA's, and a Stage 2 FastChip.
2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from http://www.MrMikes.com
Old Nov 26, 2001 | 10:34 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
thats what it is.
Old Nov 26, 2001 | 10:59 AM
Neo's Avatar
Neo
Yep That is the part that breaks the most on Thirdgens.
Old Nov 26, 2001 | 11:32 AM
JPrevost's Avatar
Car: 91 Red Sled
Look at my recent post. I've got a couple pictures on the way to simplify the tech article.
Old Nov 26, 2001 | 01:36 PM
Tas's Avatar
Tas
That happened to me before, it was the torque arm.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 26, 2001 | 10:01 PM
JPrevost's Avatar
Car: 91 Red Sled
<font face="Verdana, Arial" size="2">Originally posted by Tas:
</font>
More like a tranny mount. The torque arm mount is bolted to the tranny so if anything, it's more likely the tranny mount is cracked and not doing it's job. The torque arm bushing isn't as noticable when it starts to go bad. Do you feel a clunking sound under the center console? That's a bad tranny mount.
If you go real slow and keep the car in1st gear till about 3000rpm then shift into 2nd, hopefully it'll shift pretty hard, if you feel the clunking again...tranny mount.
If they're both original, again, it's usually the tranny mount that goes first.
Old Nov 26, 2001 | 10:13 PM
91RedFire's Avatar
Had the same symptoms here. Definite trans mount. It is pretty cheap and easy to fix too.
1991 Pontiac Firebird
52k Miles
T-Tops
Fire Engine Red
305 TBI
14" Edelbrock Element
"Pure Crempuff"
Old Nov 27, 2001 | 11:07 AM
BahamutRS's Avatar
It really is annoying to hear/feel that...but I'll vouch and say it's probably your tranny mount, saaaaaame thing happened to me. And get a poly one. It'll last.
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K&N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Old Nov 28, 2001 | 11:17 AM
Florida Bird's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
I just had the same thing and it was the trans mount. Had the car at Goodyear and I asked them to look at the trans mount that I had a bang when I took off, they told me the mount was fine but I needed $600.00 in work to replace the ring and pinion. Funny when I took out the old trans mount it came out in two pieces and since I replaced it I have no more bang. I guess I should drive the car over to Goodyear and give them $600.00 to fix the rear end now
Old Apr 15, 2011 | 10:04 AM
topher1316's Avatar
Re: Loud bang when accelerating
I know this is an old old thread, but I don't feel the need to start a new thread when the question can be answered so quickly. So here it goes, with research I have found that i need a new tranny mount. I've needed one for awhile, my speedometer recently started not working sometimes (temperamental), and my shifts are very very soft. Now could a bad tranny mount cause these issues from the tranns wiggling around?
Thank Chris
Old Apr 15, 2011 | 02:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
No - check the adjustment of your TV cable, and check your tranny fluids. For speedo, make sure the cable/wire connector is not coming out of the tailhousing (driver side).
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
loud91rs
Oct 5, 2015 10:05 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ULTM8Z
Sep 16, 2015 09:15 AM
