334cid stroker kit?
Old Dec 3, 2001 | 09:35 PM
Ride4ME's Avatar
334cid stroker kit?
I heard of this engine kit for the 305ci that
supposed to add 95-115 hp for $599.(from the website : www.enginekits.com )
But someone else said it makes a lot of torque but not much hp. What does the consensus say??
91 RS
LO3 TBI
"my first car"...
and it's what I always wanted!!!
Old Dec 3, 2001 | 09:53 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
I was all set to build a 334 motor about two months ago. I decided against it because of the extensive fabricating that is involved. You have to mill away at the block to clearence the added stroke, and since every engine is different, there is no straight foward set of "instructions". The kit does not include a set of heads or a cam, which are the biggest downfall to the LO3. I have also come to this conclusion, it's only my theory, but I feel that the stock computer will "like" a mild 350 better, if it's making the same power as a tweaked 305. I am not a chip programmer but I am POSITIVE that the computer, emissions system, and relieability factors will steer towards getting a 350. Oh and by the way, I was told by an engine builder that no matter how many corners you cut, you will spend over $1000 on making a 334, so at that point, why not spend a few more weeks of gas money and slap in a 350? Just my thoughts- Randy
Old Dec 3, 2001 | 10:03 PM
NJ SPEEDER's Avatar
why is there any milling involved? it is just the same old 3.75 inch stroke into a small block. it shoudl the be the same exact kit they sell to make a 350 into a 383, just with different sized pistons and rings.
i would vote against it only because for the price of doing a stroker you could make a better 350, and the stroker is still 16cid short.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Ride4ME's Avatar
I hear u randy and I expect to spend $1000 but I would spend $2500+ on a 350 and probably not have the same hp 170 + 105=275hp
on a 305 while an L98 is only putting out 245 hp.
91 RS
LO3 TBI
"my first car"...
Old Dec 3, 2001 | 10:18 PM
Tas's Avatar
Tas
by milling I think he meant grinding on the block to clear the rod bolts.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
[This message has been edited by Tas (edited December 03, 2001).]
Old Dec 3, 2001 | 10:45 PM
Tim- yeah, grinding sounds like a more appropriate word, but either way, it is the same kit as the 383 with different pistons. I see you did the math.
Ride4me- if you pick up a Super Chevy magazine, there is at least half a dozen retailers selling 220hp GoodWrench 350's for $1200. You do some minor bolt-ons to it and you'll have your 275hp. They also have crate motors that have been slightly upgraded with your power requirements for not too much more. You can always have someone who remanufactures engines build one to your specs, that may save even more money. There is something to be said to get yourself a good "seasoned" block anyway. It's already been stressed and the tolerances will maintain their accuracy. This is why some old racers will tell you that a motor is not working up to it's potential until it's been run and then rebuilt. It also gets the de-burring treatment. -Randy
Old Dec 3, 2001 | 10:49 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Stroking a 305 is like polishing a turd. Why waste your money? Its not the 305's lack of cubic inches that hurts it, its the small bore size. 3.73" limits the size of the valves in the heads, and also limits the amount of horsepower you can make with it. Adding more stroke to it only makes it worse. Instead of stroking it, get the "bore kit", which is a 350 block.
The $1200 350 is a non-roller 85 and earlier setup. You'd really want a 87+ roller setup. GM sells a L05 crate engine, which is a 350 TBI replacement.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
318 RWHP, 419 RWTQ
13.23 @ 107.62 MPH (2.13 60')
Southern California
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 3, 2001 | 10:52 PM
Tas's Avatar
Tas
anyone know if you can get that 3.80 stroke crank from the GM 383 crate engine? I'd love a 389 Firebird
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Old Dec 3, 2001 | 11:24 PM
Ride4ME's Avatar
Is it a size matter? 'cause a mustang 5.0
only has a 302 and seems to do pretty well.
Just a thought.
91 RS
LO3 TBI
"my first car"...
Old Dec 3, 2001 | 11:28 PM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">Originally posted by Ride4ME:
Just a thought.
</font>
That's a totaly different engine configuration. It has a big bore and short stroke which give HP. chevy 5.0s have small bore and big stokes which makes it mostly a torquie truck motor. But that doesn't mean a chevy 5.0 can't "do pretty well" itself. You can do anything to a 5.0L cevy that you can to a 5.7L, but you could do it on the 5.7L for less money usualy than the 5.0L chevy and get more power from the 5.7L.
Old Dec 3, 2001 | 11:32 PM
Ride4ME's Avatar
Taz......like what???
did u say "MORE" power than a 5.7?
Old Dec 3, 2001 | 11:37 PM
Tas's Avatar
Tas
no the 5.7L would make more (aka chevy 350) than the 5.0L chevy. Sorry I typed that post REALLY fast.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
Old Dec 4, 2001 | 09:22 PM
NJ SPEEDER's Avatar
Just a thought.
</font>
there is one very distinct and important difference to remember when asking about a ford 5liter engine. they can make a lot of power because their design is a large bore(4inches) with a short stroke(3inches). this makes for a motor that can use large cams without the cyl wall issues we have and spin safely to much higher rpm because the distance the piston is moving is shorter, making it's travel more stable.
that makes it easier to just spin the crap out of the motor to find more power, we don't have that luxury. the rest of the chevy architecture has proven itself to make more torque and have generally(in street and street/strip applications) a flatter torque curve.
later
tim
junior419
Apr 7, 2025 11:35 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
