Edelbrock Perfromer TBI
Old Dec 1, 2001 | 12:13 AM
Buck268's Avatar
hypothetically, what type of power increases would we be talking about with the following parts on a totally stock LO3:
Edelbrock Air Cleaner # 1207
Edelbrock Inatake manifold # 3704
Edelbrock Cam shaft # 3702
Old Dec 1, 2001 | 12:37 AM
Tas's Avatar
Tas
unless Vic Edelbrock is around you might want to give us more info.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Dec 1, 2001 | 09:08 AM
JPrevost's Avatar
Car: 91 Red Sled
Do NOT go with the edelbrock cam. It's a flat tappet and you have a roller setup. You would need to get new longer pushrods and the cam isn't that great anyways.
The performer TBI intake is good for 5-10hp if you have a cat-back exhaust or whatever. Usually the intake doesn't do much unless you do a cam swap and THAT is what I'm about to tell you to do.
Find a used LT1 cam from a 95-97 f-body. They're always for sale for real cheap and understand that a roller cam doens't really put on miles. They're good for 300K+ miles.
Okay, I've said too much again. If you can get the performer TBI for cheap, get it, it's a good intake for the 305 and well matched to the LT1 cam. I hope you have some sort of exhaust work done. The stock Lo3 exhaust manifolds are pathetic. Try and get a hold of at least the 305 or 350 TPI manifolds and y-pipe. They can usually be had for pretty cheap considering the cost of headers now are in the sub $200 range.
Old Dec 2, 2001 | 08:07 AM
Buck268's Avatar
as for the info, it would be a totaly stock LO3 getting the above mentioned parts. There are many different parts, so I put the basic part plus the part number. edelbrock's website has P/N's
Thanx for the detailed reply also!
Old Dec 3, 2001 | 08:22 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
If your car is still stock I would do exaust mods and ultimate TBI mods(including an open element air cleaner) first.Then like Jon said, intake and LT1 cam next.
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
Edelbrock TBI performer manifold
180 thermostat
Hooker headers
3"cat back
Zexel Torsen posi with 3.42 gears
Old Dec 3, 2001 | 08:34 PM
Buck268's Avatar
thats what I figured. I was just wondering. I was hoping (against the odds, i know) to find a L69 air cleaner assembly, instead of going the 'tradional' route of the open air cleaner.
Old Dec 4, 2001 | 10:48 PM
Camaro3051992's Avatar
Is Spending the $250 or $300 bucks really worth it to only get a whopping 5-10 HP?
92 Teal RS
Straight Exhaust,K & N
B & M Shift Kit,Mega Shifter
Old Dec 4, 2001 | 11:06 PM
JPrevost's Avatar
Car: 91 Red Sled
<font face="Verdana, Arial" size="2">Originally posted by Camaro3051992:
</font>
That doesn't make any sence. The edelbrock cam will make more than 10hp but it's still a step backwards with the flat lifters.
Get an LT1 cam, performer intake, open element, free TBI mods including fuel pressure. Do the exhaust at the same time but make sure your first mod is an adjustable fuel pressure regulator. No engine likes running leaner than stoich (14.7:1) at WOT!
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
toronto formula
Sep 10, 2015 07:31 AM
