Just so I know
Car: 1989 Camaro RS
Engine: 305 TBI (5.0L)
Transmission: 700-R4 (w/ trans kit)
Axle/Gears: 2.73 (Stock)
Just so I know
What does an OBDII and and OBDI connector looks like? I am asking because I have the computer connector on the drivers side underneath the steering column. I thought that was odd because usually in a 3rd gen the computer connector is under the passenger side dash isnt it? I have a few pics of under the dash; just want to know if this is a normal thing or someone moded under the dash.
Car: 1989 Camaro RS
Re: Just so I know
I have three more pics of the connector since I found out the first pic was blurry. sorry about that guys
Car: 1989 Camaro RS
Re: Just so I know
Thanks for the info; but isnt it wierd that is on the drivers side instead of the passenger side?
Car: 1989 Camaro RS
Re: Just so I know
Thanks for the encouragement; the engine compartment has leaves, twigs and nuts from trees; my uncle cleaned most of it out its just near the firewall it has the crap in it. would using a low pressure washer effect the tbi setup/electronics in the engine compartment. I just want to get it clean but not damage anything.
Car: 1989 Camaro RS
Re: Just so I know
I also posted a comment about the SES indicator lighting up when I have revved the engine and ran it for about 10 minutes above 25mph and after that happens the car runs great. The gauges are fine except for the oil temp gauge sticking every once in a blue moon
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Just so I know
Also, what codes did teh computer give after the SES came on?
Car: 1989 Camaro RS
Re: Just so I know
I dont have anything to read the code; I know autozone has one for ODB2 what about ODB1? would they have one.
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Re: Just so I know
you should just get an actron scaner it dose obd1 and obd2 i think its under 200 bucks use mine all the time
Car: 88 Camaro SC
Engine: SFI'd 350
Re: Just so I know
A paper clip will work. See the tech articles on this site. There is also winALDL, which is free and requires a homemade serial cable or OBD-1 cable from moates along with tunerpro-RT.
Car: 1989 Camaro RS
Re: Just so I know
Right now money is the key issue; just paid 700 to get the car runnin but didnt see this happen. So after I get my financial situation together (gotta love child support) I will save up some bones to get me a scanner and other tools I need besides getting some parts for the car.
I got the ALDL download program, I have my laptop just need the connection from the pc to the car and since the connector is right under the steering column I can just sit the laptop in the passenger seat and read it
Last edited by ccowner4life; May 19, 2007 at 06:14 PM. Reason: Automerged Doublepost
Car: 1989 Camaro RS
Re: Just so I know
I will tell ya this, even though that SES is annoying the car runs great; I keep getting soccer moms in their minivans as well as old men that are way past their driving age (more harmful than good) around time and I just get up to speed and pass em just to get away from the future accidents that maybe headed my way. Other than the small issues the car is solid; no rust just needs the nose fixed alittle (hood settled right) painted and alittle minor interior fixer upper the car is great.
