tbi -injector spacer or throttle body spacer?
Old May 21, 2007 | 01:09 AM
scooterist50's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
what would be a better a tbi plastic injector spacer-or a throttle body spacer(between intake and tb)? the injector spacer on ebay boasts better gas mileage and small hp gain. anyone even ever heard of or used these?
Old May 21, 2007 | 01:14 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Re: tbi -injector spacer or throttle body spacer?
Just bought a throttle body spacer on Ebay, haven't installed it yet. People sometimes have problems with the throttle linkage.
The injector spacer is a good idea. You may have to do some grinding on the throttle body so the fuel line fittings will clear. A lot of people say if you want to go the easy route, just stack two injector housing gaskets on top of each other.
I doubt either of the two mods do as much as claimed though, however if you can find the parts cheap, why not. Combine them with the Ultimate TBI mods.
Old May 21, 2007 | 11:31 AM
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
ultimate tbi? what do you mean by that?
Old May 21, 2007 | 11:36 AM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
look at the stickies at the top of the page that will answer most of your questions
Old May 21, 2007 | 05:49 PM
Tbi-MAX's Avatar
to the contrary belief.... in my suburban, the tbi spacer made a huge difference, as far as throttle response, this is with the 4l60 in a 95... the injector spacer was done at the same time... so yea, I think its worth it, it will be a seat of the pants difference! dont spend more than 30 on the spacer and 10 on the injector spacer. check ebay.. i would not drive my truck without one again.
Old May 22, 2007 | 11:06 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
ditto, i had put a tb spacer on my lo3 and it really seemed to increase low end torque.
evilstuie
Jan 9, 2020 08:29 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
mdtoren
Aug 16, 2015 05:45 PM
