lt4 hot cam in l03
Old Jun 11, 2007 | 02:20 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
lt4 hot cam in l03
How would this behave in this motor?
Anybody done an lt4 hot cam (I am switching to carb aswell)
Old Jun 11, 2007 | 03:25 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Re: lt4 hot cam in l03
i would also like to know anyone who has experience with this. i plan on running the same cam in mine when i get ready but im gonna stick with the TBI.
Old Jun 11, 2007 | 05:45 PM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
from what ive heard the lt1 cam is just about the biggest you can go on the stock heads
Old Jun 12, 2007 | 12:30 PM
Car: 91 GTA
Axle/Gears: stock
yes i do know that this cam will require better/higher lifting heads as well.
Old Jun 16, 2007 | 10:10 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
To run an LT4 hot cam you will need headwork. You will have to have the valve guides cut to accommodate the larger lift of that cam. You will also want to remove the pressed in rocker studs for screw in units. Running a cam past .500" lift on the stock pressed in studs is a disaster waiting to happen. The stock heads flow about 165cfm on the intake side, which means they will support near 300 hp untouched (assuming tuning and a can under .480" lift is used). The LT4 hot cam would be too much cam on the stock heads. A little porting goes a long way and would be recommended before putting in that cam. At the end of the day this combo is at the mercy of your chip tuning skills. If you cannot tune a TBI set-up a cam swap (any cam swap) is not for you.
Old Jun 19, 2007 | 11:55 AM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
You'll also need allot more air and fuel than the stock TBI can provide. When I ran TBI with a LT1 cam, torquer 305 heads and good carb intake manifold, the engine would start to develop vacuum and turn lean above 5000 rpm, no matter how the programming was tuned.
Jake_92RS
Jan 28, 2020 10:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
f-bodyz28
Sep 2, 2015 05:03 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
