spacer
Old Jun 21, 2007 | 09:35 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
spacer
is it worth the 80 bucks to put on a throttel body spacer ?
Old Jun 22, 2007 | 12:05 AM
Green89IROC305's Avatar
Car: 91 Z28 - using 87 electricals
Engine: 383 HSR EBL
Transmission: 700R4 - Stage 3 Fixed Pressure
Axle/Gears: GM 3.08 POSI
Re: spacer
i think so when i had my tbi motor i got one for free and put it on and among other things noticed better gas mileage.
Old Jun 23, 2007 | 10:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: spacer
On a stock motor no. Spend that $80 and get an LT1 cam. A spacer does increase plenum volume, which is good, but on a stock motor you can make that $80 go a lot further.
Old Jun 24, 2007 | 10:55 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
Re: spacer
well were can i get one and how much is a lt1 cam goina help me out ???
Old Jun 25, 2007 | 06:36 PM
oldred95's Avatar
Re: spacer
They sell them on ebay for about half that.
Old Jun 25, 2007 | 09:08 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
Re: spacer
and how much is that gona help my car out???
Old Jul 3, 2007 | 10:10 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Re: spacer
Once again ... does anyone have any pictures of the open space modification ? I know how to do it to the 1 inch spacer I got, but not quite sure how you do it to the intake manifold ???
And what's the difference in power range and drivability... two hole spacer... vs. open spacer with opened up intake manifold ? Would the second one be more for mid and high rpm power ? What about torque range, would it move up down ?
Old Jul 5, 2007 | 12:26 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: spacer
open plenum spacer increases top end performance and doesnt really hurt low end too much on these engines because these motors were built for torque at the lower end of the rpm range, i havnt put one on my motor caus i do not want to run a spacer and then a nitrous plate..
Old Jul 6, 2007 | 12:41 AM
1988-305-tbi's Avatar
Re: spacer
AN LT1 CAM?????????????????????????????? ON A STOCK MOTOR??????????????????????????????????????????????????? HELL NO WORST ADVISE EVER, YOU MESSING AROUND OR WHAT SHIFTY? YOUR CAR WILL RUN LIKE CRAP WITH AN LT1 CAM, AND BY THE WAY I PUT A SPACER ON A STOCK L03 MPG'S/ TORQUE NOTICABLY IMPROVED.
LOL AN LT1 CAM ON A STOCK MOTOR THATS 80 BUCKS TO BUY IT, A FEW HOURS TO PUT IT IN AND A FEW MORE TO PULL IT OUT WHEN YOU REALIZED WHAT YOU'VE DONE, UNLESS YOU FEEL LIKE SPENDING A COUPLE HUNDRED EXTRA DOLLARS TO BUY TUNNING EQUIPMENT AND DONT MIND TUNNING FOR A COULPLE MONTHS TO GET THE CAR RUNNING AS GOOD AS IT DID BEFORE THE SWAP
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
