No fuel pressure
Old Jun 23, 2007 | 11:59 AM
joebeagle's Avatar
Car: 1991 RS Convertible
Engine: 5.0L
Transmission: Standard
No fuel pressure
1991 5.0L TBI I have put in a brand new fuel pump, new screen (of course), new fuel filter, blew out fuel line from flexible hose to fuel fileter, still I get no fuel pressure. OBD1 shows no errors. Any ideas?
Old Jul 2, 2007 | 08:46 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Re: No fuel pressure
That's scary.
Mine is not working right now either. I measured the fuel pressure and could not get the dial to move at all. The car tries to start and then stalls out. I see fuel at the injectors, but it must not be enough. The car will stay running on starter fluid.
I would think that it would be either your fuel psi regulator or voltage to the pump. If the regulator is stuck full open, what would that do? Anyone?
Old Jul 2, 2007 | 11:19 AM
pimpdaddylee's Avatar
Car: 1989 camaro
Engine: 305 tbi
Transmission: stock
Axle/Gears: stock
7-2-07 i just had to be towed this morn on my way to drop my kid off. same thing i started the car this morn give it a little gas it cut off. it took maybe five min to restart .and on the way. maybe 1 mile. cut off. and would start but not stay running , it's at the shop now.
Old Jul 2, 2007 | 01:22 PM
joebeagle's Avatar
Engine: 5.0L
I'm not sure why, but my fuel pressure came back to life when I resolved the problem with my TBI catching fire. I'm not sure why the distributor has any influence on the fuel pressure, but it did...
Old Jul 3, 2007 | 12:44 PM
Car: 1989 camaro
Engine: 305 tbi
Transmission: stock
Axle/Gears: stock
update on my car they think its my ecm (aka brain) we will know soon
Old Jul 3, 2007 | 05:25 PM
Car: 1989 camaro
Engine: 305 tbi
Transmission: stock
Axle/Gears: stock
Up date it was the ecm /// thats not the problem it happen again so back to the shop
Old Jul 6, 2007 | 08:26 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
The problem is pretty straight forward. Either the fuel pump is not working or there is a clog somewhere. Where are you checking the fuel pressure at? If I remember correctly, there is a fuse connected to the fuel pump...check your fuseblock first, then try checking the fuel pressure before the fuel filter.
Old Jul 6, 2007 | 04:17 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Do you actually have no fuel pressure? or is there simply not any gas coming out of the injectors?? If the injectors are not firing it most deffinately can be caused by the dissy. The ecm requires a reference pulse from the dissy to open the injectors.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
