open air element
Old Jul 21, 2007 | 10:45 PM
n36ryder05's Avatar
open air element
Im still confused on some things after reading previous open element post.First is it better to use the flat base or dropped, and if dropped do I use the 1 1/4 or 7/8. Another question is that some people say leave the iat out and away from metal and others say put it in the air cleaner. Which is best and is there a dif?
Old Jul 21, 2007 | 11:23 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Re: open air element
This is the drop assembly I'm running:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=230128510278
Doesn't list the measurements, but fits fine. I drilled a hole in the underside and screwed the IAT in. Right now I've plugged the vacuum line that used to run to the assembly but I plan on hooking it back up when I have the time to drill some more. Had no issues with it, and that includes some "spirited" test drives.
Old Jul 22, 2007 | 10:55 AM
88L035speed's Avatar
Car: 1988 Camaro Coupe
Engine: 305 5.0 L03 TBI
Transmission: T5 - 5 speed
Axle/Gears: open diff. & stock 3.08 gears
i say you go on ebay buy the short ram intake from option racing it cost 40 buks total and it works great and i took one headlight out with a tube pointing at the filter and it works like a charm
Brinkkl2000
Aug 4, 2018 08:29 AM
Todd84Z
Sep 4, 2015 08:02 AM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
