carb to tbi
Old Aug 7, 2007 | 04:31 PM
80sBaby28's Avatar
Car: 1989 camaro
Engine: v8 fuel injection
Transmission: automatic
carb to tbi
Hi i just bought an 89 camaro that has a 305 in it and the owners before me switched out the tbi and made it a carb. there is a check engine light on and I have to be able to pass smog and was wondering how hard it would be to take off the carb set up and put back on the tbi. Thanx
Old Aug 7, 2007 | 05:29 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: carb to tbi
How dificult the reverse swap will be is entirly dependent on how much of the wiring they removed. If they just snipped everything off and replaced the TB and dissy with a carb and mechanical advance distributor then it won't be fun.
You'll just have to start from square one and get a complete setup from a donor vehicle.
The check engine light is because of all the sensors that are not hooked up.
Old Aug 7, 2007 | 06:56 PM
80sBaby28's Avatar
Car: 1989 camaro
Re: carb to tbi
So basically putting the tbi back on is all about the wiring? I can just bolt everything back up and rewire everything and that is all?
Old Aug 7, 2007 | 06:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: carb to tbi
I had to chuckle a bit, as my other thought upon reading this was: "at least the ECM is still there."
Unless the SES was hard-wired in the original swap, the ECM is required to turn on the SES light. So it is possible that some of the required items for a swap to TBI are still there.
RBob.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
