TPI Heads
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
TPI Heads
Just wondering here. I checked the local salvage yards and they have TPI heads from a 5.0L TPI engine...kicker is they are from a 1987 Chevy Caprice. Are these the same as the heads from a TPI Firebird/Camaro?
Re: TPI Heads
I should mention that these are going on a 1987 TBI Camaro RS. My buddy loves how my car feels and is super hyped on doing the same mods I did.
Car: 1987 GTA
Engine: High reving 332ci monster
Axle/Gears: 3.73 posi
Re: TPI Heads
Would you be able to get a casting number? The 081 heads which came on the 305 tpi's are great after some monye is put into them.
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
Re: TPI Heads
Stock swirl port heads can produce decent power(good off idle torque). Port the stock heads unless you got a pair of 081's sitting around.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: TPI Heads
I would get the casting numbers to be sure. Caprice cars didn't come with TPI. Unless you are going to port them I would not bother with the effort for stock swap.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: TPI Heads
The '87 LG4's came with the same 1081 heads as the LB9's. They were a pretty common head for 87+ 305's.
Car: 1983 G20 Chevy
Transmission: 4L60
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
