Lost FUEL SPRAY
Old Aug 23, 2007 | 08:17 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Lost FUEL SPRAY
Hope im posting in the correct place.----I lost fuel spray at my injectors, and i have fuel pressure.---3 hours before this ,, i put in a new reman distributor to replace mine that had 230,000 miles on it. and everthing was fine.---It will fire up on starting fluid, so i must have spark.---- Could it still be new distributor, ???? ------its a ecm controled one, and im a crossfire.-------help
Old Aug 23, 2007 | 09:03 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Lost FUEL SPRAY
Carl
In your new dizzy check ignition module and wiring harness - if ECM is not receiving reference pulse from dizzy it will not fire-up injectors.
//RF
Old Aug 24, 2007 | 06:51 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Lost FUEL SPRAY
also make sure you plugged the 2 plugs that go into the coil from the ICM ^^ i did that once and laughed after 2 hours of trying to figure it out lol!
Old Aug 27, 2007 | 08:42 AM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Re: Lost FUEL SPRAY
Was a bad reman, dist from napa. guys in case your interested
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
djmarch
Aug 19, 2015 12:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
