what works best
Old Aug 25, 2007 | 06:37 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
what works best
I was wondering what injectors could i upgrade to. I have a 305 tbi 92 rs, i have the open air element tbi spacer headers no smog 2 piece underdrive and a hypertech chip. I would like to know what pound my stock injectors are and what can the stock fuel system support and get some decent performance out of thanks.
Old Aug 25, 2007 | 09:26 AM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
Re: what works best
with those mods you stated you should have no problem with fuel im not exactly sure what they were rated at but i think they are 55 lb\per hr you might want to look into diy prom tuning insted of getting a hypertech chip just my 2 cents
Old Aug 26, 2007 | 12:32 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: what works best
so would a set of 350 injectors be better or not? im not to savy on the proms and programming them
Old Aug 26, 2007 | 11:02 AM
markymarco's Avatar
Re: what works best
im going to correct myself they are 45lb/per hr injectors yes 350 injectors are better but with those mods you would not need them
Old Aug 26, 2007 | 11:49 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: what works best
305 injectors are 55lbs/hr
350 truck injectors are 61 lb/hr
Old Aug 26, 2007 | 11:59 AM
markymarco's Avatar
Re: what works best
thanks fast, i wasent sure i read somewhere that they were 55 and the i read somewhere else that they were 45
Old Aug 26, 2007 | 05:40 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: what works best
You can't just throw more fuel at an engine and expect more power. You have to tune the chip for the fuel needs of the motor. Fast355 has made over 300 hp with the stock 55 lb/hr injectors at higher than stock fuel pressure so you don't need to upgrade yet.
Old Aug 26, 2007 | 07:38 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: what works best
thanks next queation then if i take my stock prom can i have it tuned and put one on or make the fuel pressure regulator adjustable should i see a big difference then?
Old Aug 26, 2007 | 08:27 PM
markymarco's Avatar
Re: what works best
you can tune your prom yourself even so if you do tune your chip for your mods you would not need to worry about your fuel pressure to much
Old Aug 26, 2007 | 09:05 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: what works best
how can i tune it myself im ignorant when it comes to the computer part as far as programing and how to do it
Old Aug 27, 2007 | 04:21 PM
BMmonteSS's Avatar
Car: 84' Monte
Re: what works best
Well if you're ignorant (choose not to know) then there is no help for you. If you just don't know how, we can point you in the right direction to learn. If you don't want to tune you have to be content with only making 20-30 hp over stock. The only other option is to take it to a shop that can tune, mail order chips are a sham for anything more than a stock motor. You can be DIY tuning for less than $150, just check out the "free tune" sticky at the top of the forum.
Old Aug 27, 2007 | 04:27 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: what works best
thanks ill check it out
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
