fuel injectors and intake?
Car: 1992 RS Camaro
Engine: 350 small block V8
Transmission: icky automatic
does anyone have any oppinions on the best intake and tbi set up? preferably the best bang for my buck...
Car: 1991 z28
Re: fuel injectors and intake?
if your going to swap your intake you might as well switch to TPI. WAY better than TBI for performance. Im sure you could get a complete TPI set up for realy cheap.
Car: 1992 RS Camaro
i would but i dont want to swap my harness around too much...i have bad luck with wiring. unless a TPI unit will plug right in.
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Painless wiring makes an adapter plate for using a regular bore holley manifold with your factory throttle body so that could open up some options for you.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need to post in the TBI forum. This fourm is for posting opinions of parts you've already bought.
Edelbrock makes a decent TBI intake manifold. Pair that with a Holley 670 cfm throttle body. See the "Ultimate TBI mods" tech articles.
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Moving to TBI forum.
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Now for some TBI specific tech.......TPI is NOT light years better than TBI. In fact it's cheaper to make power with TBI than with TPI. In stock form you can make the same if not a few more HP up top with TBI and only give up about 15-20 ft/lb of torque in a very narrow power band down low.
The "best" intake and TB setup simply depends on what you are doing with the car. Most likely you have a street car and just want to make more power. The performer RPM has proven itself as one of the best all around intakes for carb applications and will work great with your TBI and adapter plate. Only problem is that's it darn hard to get it to fit under the stock hood. After the RPM it's a toss up between the regular performer and a low rise single plane like weiand makes.
The only upgrade over your stock TB is the big block version, holley also sells a version commonly refered to as the (670 cfm) version. Both have 2" throttle bores, but the GM version usually has much bigger injectors (around 80 lb/hr). Keep in mind that changing the TB or injectors will most likely require you to retune the ECM to account for the changes. TBI or any speed density styel fuel injection system requires retuning for any modifications that move more air.
insert dead horse and whip here
Car: 84' Monte
Hey Kev, I don't come into every TPI circle jerk over on your board with a smart a$$ comment.....so don't come in here with your attitude.
In other words.....add some tech or get out.
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
holly makes an adapter plate as well for a carbed intake, and heres another site
http://www.cfm-tech.com/catalog/gm_t...5_products.htm
http://www.tdperformance.com/transdapt.html
a friend and i were just dicusing how to inprove his tbi suburbun my thoughts were 87+carbed intake w egr, a tbi adaptor, 454 stock tb, cold air intake , and 1.6 rockers but thats in a very heavy truck, and later full exaust and maybe a blower for show and go.
Car: 1992 RS Camaro
But then you posted something I felt was way off-base. Other than Fast355's factory freaks, I've never seen a TBI make as much power as a TPI at the wheels, and I've seen them give up a lot more than 20 lb/ft, across the power band, not just down low. But I'll leave you to your circle jerk, as you call it.
TBI does great for what it was designed, as a good MPG cruiser and daily driver. And TPI does great for what it was designed, a low RPM torque monster.
My 1991 Z28 stock with 3" exhaust: 195 RWHP, 265 RWTQ
My 1992 RS stock with 3" exhaust: 158 RWHP, 220 RWTQ
Car: 1983 G20 Chevy
Transmission: 4L60
I did, in post #5 I recommended an intake and throttle body for him.
http://www.youtube.com/watch?v=WydwLghk_yw
But Bmonte said "in stock form", not with free mods. TBI has less timing because it was designed as a cruiser to run on 87 octane.
I'll go you one better:
89 RS, 5-speed, headers, open element, free mods, 3" exhaust: 175 RWHP, 250 RWTQ.
Car: 84' Monte
Kevin, when I said "stock form" I'm talking about the induction system.....NOT THE WHOLE MOTOR. LO3's are junk they had the crappy heads and tiny cams along with restrictive exhaust. When I say TBI I'm talking about throttle body injection, not the boat anchors they were attached to.
Take a bone stock TPI system and TBI system and you can make the same if not more peak hp with TBI on a particular engine and only give up a bit of torque in a narrow power band. It's been proven.
9192camaro
16
Feb 3, 2019 12:21 AM
Firechicken86
Aug 12, 2015 10:07 PM
