Fuel Problem
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
Fuel Problem
My Buddies 88 T/A stock L03 has just developed a problem.
If he takes off with half throttle it starts fluttering and loses power.
If he lets off a little it starts running ok. If he takes off real easy it will pickuo and run ok. If he is going along 30 mph and gives it 3/4 pedal it starts missing and falls on it's face until he let off a little and then it streightens out as long as he is easy on the throttle. Do you think this is a trash in the line problem, or injector gone bad or whatever.
Input would be appreciated.
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Re: Fuel Problem
I would say start by looking for vacume leaks...especially around the egr. I would also check and see that the egr is operating correctly.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Fuel Problem
Check Fuel pressure while in park under various RPM's. TBI fuel pressure should be steady 13 PSI. If it drops significantly you got tired FP or ripped fuel pump to feed through in tank hose.
//RF
//RF
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
