edelbrock tbi cam
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: edelbrock tbi cam
Yeah, your probably right. Thats a 929 type cam. Not much better then stock. You wouldnt even notice much of a difference.
Car: 88 Camaro SC
Engine: SFI'd 350
My crate 350 came with the GM version of it. The motor was a complete dog with that cam. The power was done and gone by 4k.
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Car: 1983 G20 Chevy
Transmission: 4L60
Whats the big problem with the cam???????dont tell about roller cams i dont have a roller block. dont want to burn chips either. i really want first hand info on the cam not opinions.
Car: 1983 G20 Chevy
Transmission: 4L60
Need we spell it out for you. We know the cam. The cam rivals the stock "929" cam. It is not even noticeable over stock. I would recomeend something a little hotter. 214/214 or so, of course you will need to burn chips. If you don't want to burn chips, leave the engine STOCK.
I PUT IN THE EDELBROCK CAM AND PUT ON SOME TUNE PORT HEADS. AND IM VERY PLEASED WITH THE CAM . I ALSO PUT ON ROLLER ROCKERS , DOUBBLE TIMMING CHAIN,AND PERFORMANCE BALENCER. BASICALLY THE CAM IS WORTH IT( COMPUTER COMPATABLE ALSO). I HAVE IT THATS FIRST HAND INFO . NOT OPINION ON SOMTHING I DONT OWN LIKE A LOT OF INFO GIVEN ON THIS SITE.
Car: 1983 G20 Chevy
Transmission: 4L60
Competition cams makes a very nice XE grind cam for a computer engine. The XE 256 computer cam would run VERY nice in a stockish L03/L05.
Car: 91 maro
Axle/Gears: 373 locker
yea that cam sucks thats not a opinion ur car will do a tenth of a second faster in the quarter maybe with a chip its not worth it just get a cam a lil bigger what ever block u have roller or machanical they sell cams
Car: 88 Camaro SC
Engine: SFI'd 350
Car: 88 Camaro SC
Engine: SFI'd 350
Like said above, something like a base XE grind would be good. Also a single pattern would probably go well with the TPI heads as the I/E flow is fairly close. Maybe a 208/208, 210/210, or similar with a 112 LSA if this is a truck. It will have good vacuum and make good low/midrange torque with the smaller runner TPI heads.
junkcltr
Aug 2, 2019 11:12 PM
