Knock sensor
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Knock sensor
Any ideas where to get a knock sensor? I am putting a 350 top in my 305 engine.
Engine: V8 305
Re: Knock sensor
keep the base 305 just put a 350 top...ie: 350 injectors, chip, knock sensor etc.
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Knock sensor
If all you are doing is replacing TBI there is no need to replace KS. KS is a sound transducer tuned to a block - cam - head combination. Each engine combo (350, 305, 267, V6, roller - non roller) has slightly different resonant frequency, as well as knock dominant frequency. So depending on application KS is designed to have frequency response targeting dominant frequency of a ping. Additional frequency selectivity is done inside ESC module - but it is more of threshold detector - amplifier.
In your case, since you are not changing block, heads, cam - I would leave KS alone.
//RF
//RF
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Re: Knock sensor
The knock sensor and ESC (module that the knock sensor plugs into under the dash) are the same for the 82' F-body 305 and the '82 Corvette 350. I recently researched this point.
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Knock sensor
ALOT of Vans and Trucks have the same pieces between them. I also found out that a LT4 used the same knock sensor as a 1996 C1500 truck with a 305.
FormulasOnly
Sep 10, 2015 09:07 PM
