stallin issue
Old Oct 1, 2007 | 11:26 PM
Stockk5's Avatar
stallin issue
Hey guys i have a 1987 K5, 350 TBI w/ a 700r behind it. I was having problems recently with it over heating in traffic, new ignition module fixed that. I have put a new fuel filter on, new coil but now a new issue came up. I am driving down the road, slow down and go to turn left, my truck ALWAYS dies, the engine just shuts off and i have to pull over and hope it restarts. It wont do this turning right.. what could be the problem?
Old Oct 2, 2007 | 12:14 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: stallin issue
K5 it is most likely that you have a fuel starvation. If I recall, 87 used plastic baffles inside the gas tank to keep fuel sock from uncovering during turns. The baffles are known to break off as tank ages.
You can verify if baffle has broken off by fueling up and making couple of sharp turns. It should be ok with full tank, but once you get below 1/4 tank sharp turns should cause your engine to stall.
//RF
Old Oct 2, 2007 | 01:14 AM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: stallin issue
well if you have a Stalin problem then you should call the US embassy in Russia and hope for the best. lol. (okay sorry, i have bad humor)
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
