Cold air intake
Old Oct 4, 2007 | 10:35 AM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
Cold air intake
Is it possible to have a cold air intake system/ram air system on a tbi or is it only reserved for tpi's
Old Oct 4, 2007 | 11:00 AM
Ronny's Avatar
Re: Cold air intake
cold air is available from aftermarket. also works on a carb.
Old Oct 5, 2007 | 05:50 PM
91RS/SR355's Avatar
Re: Cold air intake
I built this with junkyard parts out of an 89 IROC (upper filter housing), 91 Z28 (lower filter housing), an 89 Buick (Airlid?) a V6 Firebird elbow, some 8" Air Conditioner ducts (mount behind grill) and some rubber plumbing tube. Total cost $30ish. You can definetly feel the power and hear a cool whine at high RPMs.
Old Oct 6, 2007 | 09:25 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Cold air intake
It's been covered a cajilion times......no really a cajilion
You need to jump up to the stickies throw in some popcorn and start reading. All of the questions you have been asking are answered up there. It just takes some effort on your part to read through all of them and take notes. All that stuff about note taking they tought you in school really does apply to the real world.
Old Oct 6, 2007 | 11:35 AM
Engine: V8 305
Re: Cold air intake
Thanks 91RS/SR355, some really awesome info there, thanks again. Where did you get the " Camaro Ram air " ?
Old Oct 8, 2007 | 07:15 PM
91RS/SR355's Avatar
Re: Cold air intake
Youre welcome goalieforlife. I just found some pictures on google, printed them out, traced and cut them as stencils. Looked good to me glad you liked it.
Now Ive just got to adapt it to fit this... Should be easy since the BBK Throttle body is for a TPI/LT1.
Old Nov 5, 2007 | 10:38 AM
Engine: V8 305
Re: Cold air intake
anywhere to buy cold air intake for a 92 bird, v8 305tbi that is completed and all I would have to do is install?
Old Nov 6, 2007 | 11:07 PM
Engine: V8 305
Re: Cold air intake
bump
Old Nov 7, 2007 | 02:36 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Cold air intake
https://www.thirdgen.org/forums/tbi/...ir-intake.html
Old Nov 7, 2007 | 06:13 PM
Engine: V8 305
Re: Cold air intake
thank you
Old Nov 8, 2007 | 09:31 AM
Ronny's Avatar
Re: Cold air intake
check out Ram Air Systems the advertise in Hot Rod Mag and have an assortment of units to fit almost everything. Unfortunately not my car(vette).
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
