recomend me a AFPR
Old Oct 17, 2007 | 10:00 PM
BackInBlack86's Avatar
Car: 77 K20 80 K2500 93 C2500 94 K1500
Engine: 350 350 454 350
Transmission: 350 465 80E 60E
Axle/Gears: 4.10 3.73 5.13 3.73
recomend me a AFPR
i'm looking for a stock type AFPR for my 92 C1500 5.7. which one is best, and why?
Old Oct 17, 2007 | 11:51 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: recomend me a AFPR
IMO an External regulator from Ebay plumbed into the return side is the best option.
Old Oct 18, 2007 | 12:13 AM
IMO we already talked about that on FSC... it is NOT an option. i refuse to buy cheap parts, and a good regulator will run me more than a stock style AFPR and a complete set of fuel lines from the tank to the throttle body. external regulator is NOT going to happen.
Old Oct 18, 2007 | 12:18 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I haven't looked at that post after my post earlier today. Stock type regulators are very inadequate. They have very limited adjustability with the stock spring, roughly 9-14 psi Cheap does not necessarily mean bad. My regulator was very well constructed and only cost $69.00 shipped.
You can DIY an adjustable stock type regulator pretty easily.
Old Oct 18, 2007 | 12:24 AM
if i were to do the DIY AFPR mod, along with a small spacer, i should be able to surpass the 14 psi limit that just the DIY mod will give you correct? if im tearing into it, i'm doing a full rebuild of the TBI, new diaphragm and spring in the FPR for sure. i already have a Z28 TPI pump in the tank, so the pump handling it wont be a problem.
sorry for seeming short in my previous post. i just realized i dont have the same ID as i do over there, so unless you read both profiles very carefully you wouldnt have a clue it was me.
Old Oct 18, 2007 | 08:29 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The stock spring coil binds somewhere around 14-16 psi. Once this happens the pressure shoots unpredictably high with only a slight tweak to the regulator.
Old Oct 18, 2007 | 10:45 AM
Ronny's Avatar
Last I heard you can buy a "one step" stronger TBI spring from an advertiser on this forum top down solutions. i bought one a while back and it is maybe 10-20% stronger....
Old Oct 18, 2007 | 12:08 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
That spring is $4.75 at TDS. If that doesn't fit your budget, nothing will!
Old Oct 18, 2007 | 01:41 PM
Ronny's Avatar
Group buy !
Old Oct 18, 2007 | 02:16 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
just about any spring made of music wire with the right dimensions will do if you want more then 20 PSI. Lots of large suppliers carry these types of springs. I used a spring from mcmaster carr to get stronger springs so I could have 30-50 PSI of fuel pressure.
Old Oct 18, 2007 | 05:29 PM
just looking at the xtreme-fi regulators on Ebay. they say 8-40psi, which should more than cover what im wanting to do, and the price isnt bad. is this unit any good? supposed to be easily adjustable without removing the injector pod.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Zane Story
Oct 8, 2015 12:40 PM
355tpipickup
Sep 4, 2015 05:32 PM
