350 headers on 305 help
Old Nov 22, 2007 | 05:50 PM
89IrocPballa's Avatar
Car: 1989 Chevrolet Camaro Iroc Z
Engine: LO3
Transmission: 5 speed
Axle/Gears: stock
this might be a stupid question but if i took 350 TPI stock headers and bolted them on my LO3 would they flow a lot better than stock. i really can't afford new headers and somebody reccomended this to me andi thought i would ask you guys about waht ou thought about it. i don't need like new header performance but near that.
Old Nov 22, 2007 | 06:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 headers on 305 help
These cars didn't come from the factory with headers, they came with manifolds.
Old Nov 22, 2007 | 06:06 PM
Engine: LO3
Axle/Gears: stock
thats what i meant
Old Nov 22, 2007 | 06:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
L98 manifolds would be an improvement on LO3s, maybe not enough to make it worth swapping. Neither would be nearly as good as headers.
Old Nov 23, 2007 | 01:34 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes you can do that, but you will also need the y-pipe and cat setup, too. The TBI y-pipe will not bolt up to the TPI manifolds. Also, there are 305 TPI manifolds out there that are identical to what you have, so you dont want to swap on those. The best thing to find is a dual-cat setup from 89-92 TPI's. They came on both 305's and 350's. Otherwise, a single cat setup from a car with a 2.75" i-pipe, not a 2.25" i-pipe, will be what you want.
Old Nov 23, 2007 | 05:19 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
for the time it would take to do that, I would just get real headers, I put some on my 305, best thing ive done yet
Old Nov 27, 2007 | 04:38 PM
yellow92bird's Avatar
I have a 92 firebird with a lo3 and put a cheap 100 dollar set of headers and true dual exhaust with flowmaster 40 series also added two high flow cats. BESt thing ever to do to a F-body car. unleashed about 45 hp
Jake_92RS
Jan 28, 2020 10:37 PM
Wvcamaro
Sep 4, 2015 08:38 PM
theurge
Aug 21, 2015 12:46 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
st.evel07
Aug 13, 2015 06:15 PM
