Help, info needed
Old Nov 25, 2007 | 08:48 PM
mr. maro's Avatar
Help, info needed
Hey guys a buddy of mine has a limited slip posi rear end that was set up for disc brakes. He is givin it to me to put in my 89 camaro rs tbi. What do i need to do to put this in my rear which has drum brakes? I wanna keep the drums, just want to know if there is any way i can put this one in cheap?
Old Nov 25, 2007 | 08:53 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
Re: Help, info needed
An 89 RS with TBI should have a 10 bolt rear. What car is the rear out of? Do you know if it's a 9 bolt, a 10 bolt??? And if you want to keep the drums I don't think you can put drum brakes on a disc brake rear. If you want to keep the drums you can just buy a limited slip carrier for your 10 bolt without having to swap the whole rear. I swapped rears on my 88 Camaro only because I wanted rear discs as well as the limited slip posi.
IROCZ1989
Jan 24, 2016 03:55 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
