open element air cleaner
Old Dec 3, 2007 | 02:50 PM
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
i have a 91 305 TBI and i was just wondering what air cleaner i should go with. i just called summit and the guy told me that nothing would fit.does anyone have a part number to make it a little easier?
i really like the look of the flat black one that chevy has but i dont know if it will fit or not. http://store.summitracing.com/partde...5&autoview=sku
what have you guys used. also which crankcase breather should it get?
Old Dec 3, 2007 | 02:54 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: open element air cleaner
any of the 14X3 ones should fit, I dunno why he would tell you none would....I have an edelbrock open element on mine, im carb, but a guy in my club has the same one on his TBI and it fits
Old Dec 3, 2007 | 03:55 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Yea several air cleaners will fit. I have the Edelbrock Pro-Flo 1000 on my car. It's cheap, functional, flows well, and the foam insert is washable.
You do not need to use the carb stud holdown bracket that comes with it. You will however need o eyeball where the center is cause you have to punturs the TBI stud through the filter and then thread it into one of the grille openings. This is fairly quick and easy to do. It has plenty of clearance and flows 1000CFM which is more than enough air. It is a drop base but it has a very smooth turn down. It's not tall enough to make it a non drop base. There are no issues getting air to the the throttle bores though. If you have an injector spacer and a modded TBI unit there shouldn't be any shrouding even with the drop base.
Old Dec 5, 2007 | 03:23 PM
Demon_Eater's Avatar
Car: 91 Camaro RS
heh, I totally agree with you,
Im sorta thinking he's just like this guy in my town that works at car quest that "this wont fit", "This wont work", "you cant do that". a guy who thinks he knows it all, but doesnt know anything about engines.. ahaha.
anyway, I have a edelbrock open element too, works really well, eventually im gonna get a whole new open element, cause the one I got the paint is coming off, has spot, and air cleaner needs to be replaced.
Old Dec 6, 2007 | 08:19 AM
kaupca's Avatar
Car: 92 Camaro RS
I got a 14 X 3 Chrome one from Autozone that had a flat base. Took the spacer ring off the top of the throttle body and it fit great. Just watch for it rubbing the wires going into the distributor. There should be enough room but good to check.
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
