"Custom Throttle Body For TBI Applications"
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Some of you may remember that project that my cousin and I were working on awhile back called "Conan". Well, I'm actually in the market again for a manual transmission daily driver, and I'm targeting an LO3 w/5-speed. Got a little time before I throw down my money on an ebay inspired car, and I'm not going to rush the purchase. However, in the interim, I pulled out all of the stuff that we were working on from project "Conan", in preperation for the next car that I come across. The throttle body, in which will be taken to the next step, along with the Holley ProJection Intake, currently looks like this....;
First pic w/out throttle plate, second with throttle plate, third w/throttle plate opened.
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Re: "Custom Throttle Body For TBI Applications"
pretty slick fab work, I like it. Smooth throttle motion? I would imagine that could support quite a bit of power. What will you be putting it on top of?
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
By running a mono-blade and removing the center section ... Nice work by the way I'm not criticizing it .... But with the center removed like that under typical to excessive heat wouldn't you run th risk of the throttlebody potentially cracking in that area? ... Also from heat Could it potentially distort and cause the throttle shaft to bind?
Or are you also running something under the throttlebody to insulate it from excessive intake heat?
Originally Posted by Jproz1167
By running a mono-blade and removing the center section ... Nice work by the way I'm not criticizing it .... But with the center removed like that under typical to excessive heat wouldn't you run the risk of the throttlebody potentially cracking in that area?
Very interesting concept you've got there. I can only imagine the CFM's a 454 throttle body would flow like that. A question does come to mind though. Why not go ahea and completely open up the middle section so its one big oval shaped blade? Did the vacuum passages not permit this or is there some other reason I'm not seeing? As for the strength and fatigue of the throttle body I can't really imagine that being an issue. Most aftermarket intakes are not heated as it is.
Can you make me one?
After looking at the pics again I notice you can only remove so much material before you loose the injector pod mounting surface and the air cleaner stud boss. Still even at that I can forsee a 1000 cfm 454 throttle body pretty easy.
Originally Posted by 91chevz71
nice, wish I had one
Your basically saying don't run EGR and use that port for the MAP or just T into the EGR vacuum hose and hook the MAP in there.
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
I like what you did with the ProJection manifold. I've got a GMPP Vortec TBI intake but I've been contemplating using a dual plane carb manifold. I'm not sure if I want to go that route because of issues with the throttle cable/TV cable bracket. It looks like a good way to run a dual plane on a TBI without any issues as far as keeping EGR and the throttle/tv cable bradket.
Gene
Gene
I've got a GMPP Vortec TBI intake but I've been contemplating using a dual plane carb manifold.....
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
not a lot of engines that could utilize tbi for fuel delivery need a significant amount more flow than a 2" tbi can give. You will lose some velocity I think and atomization but I'm sure you can get it to work, i just dont know if it will really yeild the improvement a lot of people hope for with bigger throttle bodies.
Originally Posted by snflupigus
not a lot of engines that could utilize tbi for fuel delivery need a significant amount more flow than a 2" tbi can give. You will lose some velocity I think and atomization but I'm sure you can get it to work, i just dont know if it will really yeild the improvement a lot of people hope for with bigger throttle bodies....
evilstuie
Jan 9, 2020 08:29 PM
mdtoren
Aug 16, 2015 05:45 PM
