engine dieing
Old Dec 23, 2007 | 10:22 PM
70gmc's Avatar
Car: 1970 GMC LWB Street strip
Engine: 383 stroker
Transmission: 350TH
Axle/Gears: 12 Bolt 4:11
engine dieing
Its hard to explain but ill do my best. When you start the car it idles for a split second then drops RPMS and dies. STart it up and it does it again. Start it again and rev it up for about 5 seconds and let up and it will idle. It SEEMS that the colder it is the more likely it is to do it.
I have no idea what this is or were to start. any help would be greatly apprcieated.
the car is a 92 RS 305 700R4. All stock with only 96,000 on the ticker. Thanks again
Old Dec 24, 2007 | 01:40 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: engine dieing
With colder temperatures engine needs more fuel. You did not mention how engine behaves once it is running at normal operating conditions. It is possible that you have couple of problems:
1) Low fuel pressure - stock TBI needs about 11 to 14 PSI to be happy. TBI will run with even lower fuel pressure, but start-up and acceleration will be severely impacted to say the least.
2) IAC is stuck or gummed-up
3) Possibly weak spark.
4) Malfunctioning TPS and or CTS
//RF
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
