MSD PARTS WILL THEY WORK?
Old Jan 11, 2008 | 06:11 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
hey guys i got the MSD 6a box, and the MSD p/n 8360 distributor and blaster coil. can i replace my stock ignition with this? and also will it give me a better timing and spark?
Old Jan 11, 2008 | 07:23 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: MSD PARTS WILL THEY WORK?
MSD 8360 will not work with your ECM. If you install it ECM will never fire injectors! Depending on your current dizzy type - small hat, external coil HEI with EST: MSD 8366 or Accel 60109 can be used. If you have a full size HEI then Accel 59109 will work (HEI w/o vacuum advance, 7-pin module). MSD 6A box should work with stock dizzy. For what it's worth you current ignition is more than adequate. Just replace tired rotor/cap and wires. A better coil and EST module can be added later.
//RF
BRoss99
Aug 10, 2025 05:08 PM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
