G-Tech RR
Old Feb 1, 2008 | 10:28 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
G-Tech RR
http://www.gtechprostore.com/cgi-bin...ion&key=020230
Any one with any experience with this and the l03? Is it worth the 300$?
Old Feb 1, 2008 | 07:15 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: G-Tech RR
the only thing i found that good for was comparing the difference when i added a performance part to my car. otherwise it wasnt too accurate although maybe my setting were off.
Old Feb 1, 2008 | 07:38 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: G-Tech RR
Well if it works on like a lot of newer and older cars, then that sounds to be pretty handy to have.
I know this question has been asked somewhere before. But how can I read like error codes and stuff? [im too lazy to search right now]
Old Feb 1, 2008 | 11:55 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: G-Tech RR
Oooorrrrr, you can buy the EBL to do the same thing and tune your car at the same time.
Old Feb 2, 2008 | 10:42 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: G-Tech RR
Mind linking to the EBL?
Old Feb 2, 2008 | 11:51 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: G-Tech RR
I was curious as was well, but G-Tech website is rather sparse on technical details about their product. However, from what I was to see it appears that RR super duper monitor is based on a three-axis accelerometer. Three-axis accelerometer, for consumer market, are typically solid state devices (MEMS, piezoresistive, CMOS, and other technologies are used) and can be had for very little money. Depending on accuracy required the price varies accordingly. Therefore, it is g meter that monitors acceleration and engine RPM. By entering car's weight (mass) Force - aka HP can be back calculated from observed data (recall F=m*a). With RPM data available Torque can be calculated as well. Newtonian physics still works in 21st century.
//RF
Old Feb 2, 2008 | 12:27 PM
Re: G-Tech RR
www.dynamicefi.com. Or find Rbob in the DYI tuning forums. He's the one who makes the EBL.
Old Feb 2, 2008 | 12:52 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: G-Tech RR
So it does everything the G-Tech does, plus I can tune my car? Im sold, lol.
//RF
So it basically uses math equations to calculate everything? Guess thats why people say its a little off.
Old Feb 3, 2008 | 01:04 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: G-Tech RR
i wouldn't say that, math and physics can't lie, thing is just like desk top dyno it's only as good as the user entering the information.....
in other words if you guess your car is 3,200 lbs like a bunch of people say theres are on here and you actually have a fully loaded 3,800 lb car then sure your times will be off a few tenths and hp will be off too of course.
remember all a dynamometer is, a program that basically does the same thing just using a bit different math.
Old Feb 3, 2008 | 01:09 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: G-Tech RR
Provided you have the correct speedo gears for your rear, and you dont have a cable driven VSS, the EBL equipped ECM is pretty good for datalogging vehicle speed, 0-60 times, and other info. Power is a little harder as the VSS isnt quite accurate enough to give a smooth acceleration curve. Even the later model ones with magnetic pickups fluctuate enough to make it inaccurate.
Old Feb 4, 2008 | 04:35 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: G-Tech RR
Ill keep that in mind, but as is, it looks like the best option since it can tune my car and stuff too. How do I find out what gears I have in the rear? Cant you tell what options my car has by that sticker on the door? If you can Ill take a pic and start a new thread to see what my car came with from the factory.
My cars got power everything, so I bet its on the "fat" side, lol.
BAK12484
Nov 27, 2001 02:57 AM
silver89Rs
Nov 7, 2001 07:47 PM
IrocJT
Jun 8, 2001 10:10 PM
91Bird305
May 12, 2001 07:41 PM
My90Iroc
Aftermarket Product Review
May 9, 2001 05:39 AM
