Turbo
Old Feb 5, 2008 | 08:00 AM
TransAmRocker's Avatar
Turbo
I was wondering how would it be to run a 12 psi turbo with a TBI setup.
Old Feb 5, 2008 | 10:12 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Re: Turbo
Do you have lots of money?
Old Feb 5, 2008 | 11:33 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Turbo
do you know how to tune like its your job?
Old Feb 10, 2008 | 12:31 PM
Re: Turbo
Ive put a turbo on my buddy's CRX, will it way different? Can I use a turbo from like a honda or w.e and make it work?
Old Feb 10, 2008 | 01:24 PM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Re: Turbo
Your gonna get alot off "It's not worth it to turbo TBI" Asking that question. But it can, and has been done. There is a guy over at the fullsize chevy truck forums who just accomplished his turbo TBI. There are various ss454 truck owners with blow-thru superchargers, and a turbo or 2, doing just fine. The biggest issue is fueling. I have started gathering parts for my own TT TBI project. I would get the EBL from www.dynamicefi.com. This allows you to use a 1 bar map, for 15 psi boost. I has table to increase injector PW and retard spark. Get a BBC TB with the biggest injectors, 90 pphs, and get a boost referenced regulator. You can control the BPC in the ebl. Depending on power level, you will still need more injector, so you would have to either get a 4bbl tbi unit from holley, or get an aux injector controlled and add 2 injectors in a spacerplate. Then like has been said, you REALLY need to tune it.
Old Feb 11, 2008 | 06:02 PM
Re: Turbo
K, thanks! Would it be more with it to TPI it or turbo it?
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
