TBI Air Cleaner Stud
Old Feb 11, 2008 | 03:28 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I feel like this should be an easy thing to find but dang if I can't get a local parts place to source this part for me.
Is there a web resource I can go to to order just the air cleaner stud for my TBI unit? It's become stripped from all the times I've tightened the air cleaner off and on the top of the motor.
Don't hate me for the silly question!
Old Feb 11, 2008 | 03:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: TBI Air Cleaner Stud
TBI doesn't use a normal carburetor air cleaner stud?
Old Feb 11, 2008 | 03:59 PM
Cadillac's Avatar
Mine is not straight. Makes two 90* turns before heading out the top of the air cleaner.
Old Feb 11, 2008 | 04:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ah, ok. Try a junkyard or a dealer.
discostu's Avatar
I had the same one in my '89 G30 cube van.
Might have to go junkyard hunting for a TBI van application.
Old Feb 11, 2008 | 04:13 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
some have done the "all thread" from a home inprovemnet store. it's just a threded rod then you put it in a vise and bend it the way you want it to go. becareful of the top and bittom threads though.
Old Feb 11, 2008 | 07:44 PM
Cadillac's Avatar
There's gotta be a good source for this part on the web!
Old Feb 11, 2008 | 07:55 PM
1montess's Avatar
I found one on Jeg's
http://www.jegs.com/webapp/wcs/store...0002_370365_-1
If the link doesn't work just search "TBI stud"
It's only $4!
Old Feb 11, 2008 | 08:00 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i had the same problem . tried allthread , it works i was not happy . then took a 1/4 steel rod , bent to shape , threaded both ends . now i'm happy . 1/4x 20 threads .
Old Feb 11, 2008 | 10:57 PM
Cadillac's Avatar
It's only $4!
12 dollar handling charge! Bah!
For Pete's sake. Thanks for the clue though.
I'm wondering about rethreading the stud... that's possible, no?
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
