EDELBROCK INTAKE MANIFOLD--->TBI OR CARB????
Old Feb 19, 2008 | 08:59 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
Hey guys i just got a TBI intake manifold, i was wondering if i should go with the TBI intake manifold or a CARB intake manifold. basically looking for your guys opinion. what do u think is better???
Old Feb 19, 2008 | 09:43 PM
ljnowell's Avatar
Re: EDELBROCK INTAKE MANIFOLD--->TBI OR CARB????
i believe that the carb manifold with the adapter would probably be better. However, will it help an otherwise stock lo3? maybe not.
Old Feb 19, 2008 | 09:50 PM
Car: 88 IROC-z
Engine: LO3 V8 305
car is not that stock have a few mods going in ,. cam, new tb , exhaust, intake, springs soo im wondering wats better thanx
Old Feb 19, 2008 | 09:52 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
i would have to agree the carb intake will be better than the tbi intake, but not significantly for a stock LO3
Old Feb 19, 2008 | 09:57 PM
Car: 88 IROC-z
Engine: LO3 V8 305
when u say stock whats stock to you and also how much of a difference will u see or feel if u go with a carb manifold? and why is a carb manifold better?
Old Feb 19, 2008 | 10:17 PM
ljnowell's Avatar
what kind of cam do you have? list you mods in more detail. Basically though, i think that a cam, and other minor mods and you would benefit. Probably benefit more from better heads though.
Old Feb 19, 2008 | 10:20 PM
Car: 88 IROC-z
Engine: LO3 V8 305
LT1 cam and springs
projection 670cfm TB
3" no cat exhaust
headers
open element airfoil
a/c delete and smog
i know i would see more performance from heads. but i need to know if there is a big difference in between the 2 intake manifolds. i would like to know if there is more gain or less gain from each. and why is the TBI intake manifold soo much money? just wanna know the specs on each.
Old Feb 19, 2008 | 11:04 PM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
ill have to agree wit them and say the carb manifold and the diff is the tbi one is just a aluminum stock manifold that flows a lil bit better flowin and the carb one has plenium area that distribute the fuel/ air mix better
ps id recommend the non EGR one too because it has a taller deck height
midge54
Dec 27, 2019 04:14 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
86IROC112
Aug 17, 2015 02:00 PM
