i have 2 problems on my hands
Old Feb 25, 2008 | 03:50 PM
TorqueTilla's Avatar
Car: 1991 camaro rs
Engine: 305tbi with mods
Transmission: t-5
Axle/Gears: 3.08
Well guys i came across a few problems with the camaro, first off it seems i have oil on the intake manifold? not sure what it is, mabbe a loose gasket? the other thing isnt as important but i just installed my open element and followed all the directions, seems as tho i hear a hissing noise whenever i rev it or while im driving, any ideas would be alot of help
Old Feb 25, 2008 | 07:02 PM
deadtrend1's Avatar
Re: i have 2 problems on my hands
oil on the manifold could be valve cover and or intake manifold gasket. Clean it up real well, then run it and it will give you a idea on where the leaks origin is.
As for the open element. The stock assembly quiets the sound of the throttle body ALOT. As long as you capped off the vac line for the heat stove, plugged in the IAT, made sure its sitting flush and not sitting on the coil wire ..... your ok.
Old Feb 25, 2008 | 08:01 PM
Car: 1991 camaro rs
Transmission: t-5
Axle/Gears: 3.08
yeah i figured it was just a gasket, as for the open element, somedays it feels like my car is pulling like a horse, honestly it feels like a different car, then days like today i give it gas and it feels slower then wen i had the stock air cleaner on, ne ideas?
92camaroJoe
Jul 29, 2023 07:57 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
