Knock Sensor Location In a 1970 block
Old Mar 3, 2008 | 12:20 PM
Killerzracing71's Avatar
Im putting a 358 1970 Block in my Caprice and i need to know where the Knock sensor should go
Old Mar 3, 2008 | 12:54 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Knock Sensor Location In a 1970 block
Doesent it replace a certain freeze plug?
Old Mar 3, 2008 | 01:05 PM
IDK thats what TBI chips guy told me.. but im not sure his exact words put it in the water jacket.....
SO the only way to do that without redrilling the block use the Freeze plug
Old Mar 3, 2008 | 01:48 PM
It's not a freeze plug.
It goes in the pass side block drain hole.
All SBCs, from 55 up, have that hole. Before there was the necessity for a knock sensor, there was usually a pipe plug in it.
Take the pipe plug out of your block and put the KS there instead. Don't forget to put a bit of sealer on the threads, and don't over-torque it, as that makes it SUPER sensitive. Use the Loctite/Permatex "automotive pipe thread sealer with Teflon" and about 12-15 ft-lbs.
Old Mar 3, 2008 | 01:50 PM
Old Mar 3, 2008 | 01:55 PM
sixty's Avatar
If you using block hugger headers you won't be able to install it in the drain. I need to find somewhere to install mine. I'll probably re-thread the hole above the oil filter to NPT.
Old Mar 3, 2008 | 01:59 PM
I wish i had headers Im broke as a Joke.... reusing the stock Manifolds for now till my money gets right......
Someone want a 1971 Ford Torino GT 3grand no rims Magnum 500s extra for 18s n 20's
http://www.torinocobra.com/guest_htm/travis_johnson.htm
http://www.impalassforum.com/vBullet...d.php?t=194626
So i can FIx my wagon on up
Old Mar 6, 2008 | 06:56 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
woo hoo another caprice owner! what year. did you come over from impalassforums per chance?
never mind i didnt see your sig right away.
Old Mar 7, 2008 | 08:44 PM
lol yeah im on ther ha ha
9192camaro
16
Feb 3, 2019 12:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
