Valve stem seal questions
Old Mar 10, 2008 | 04:41 PM
ghetto wagon's Avatar
I needed to replace the valve stem seals on my L03 for 5 years now. It barely runs when its cold due to all the Oil it eats when its 20 degrees out.
What is the best way to hold up the valves? TDC, or use air..
The compressor I have is a 3 gal, that pushes maybe 150psi. Will that work? Is the compressor going to kick on every 2 seconds because it has no volume?
Also, Whats the verdict with these Felpro viton intake Valve stem seals. They fit on both the Intake and exhaust valves? I have two packages of Intake valve seals now. Im reading that some had trouble with the fit on the exhaust valve.
Thanks.
Old Mar 10, 2008 | 04:48 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: Valve stem seal questions
In Shifty Capone's LT1 cam digest, he recommends taking a big length of nylon rope (like you would hang a clothesline with) and feeding it into the spark plug hole untill you cant get anymore in there. That should fill up the area between the valve and the piston head.
Another thing I read on here, is that you can rotate the crank every time, and if that piston is TDC, the valve will fall in a little, but you will still be able to pull it back out.
Personally, I have never worked on a motor yet. I just read alot. So good luck!
Cameeeero
Sep 18, 2015 04:00 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
1985chevydude
Aug 20, 2015 12:29 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
