clogged return line
Old Mar 10, 2008 | 07:08 PM
G0t M4xx 21's Avatar
Car: '91 Camaro RS
Engine: 305 TBI
clogged return line
I've been trying to diagnose a fuel system problem with this L03 for a while, checked the fuel pump, replaced the FPR, as well as the injectors (somebody had put the wrong ones on, 80 lb/hr), but it's still been running rich
Finally went and installed a fuel pressure gauge, was reading 20psi
Followed the instructions to make the stock regulator adjustable, still nothing, always 20psi
So I think my return line is clogged. I disconnected it where the engine hardline connects to the chassis hardline with a rubber hose, ran a hose from the engine line to a gas can, started the engine, now my FP is 12psi.
So what's the best way to clear a blockage in the return line? I tried fishing a stiff wire through there but didn't really do a whole lot
Old Mar 10, 2008 | 08:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: clogged return line
Maybe try blowing it out with compressed air, but if that doesn't work you might be replacing the line.
Old Mar 10, 2008 | 08:40 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The return and vent lines may be switched at the tank. The line for the CCP vent has a restriction in it. Check each with some compressed air (take gas cap off first). If the CCP vent line flows easily, and the return doesn't, probably switched at the tank.
RBob.
Old Mar 20, 2008 | 02:42 AM
Car: '91 Camaro RS
Engine: 305 TBI
all right, think I got it fixed
I don't remember exactly how the lines hook up to the sending unit, but I assume the return line goes all the way to the bottom of the tank? I blew on the return line at the tank (unhooked the short length of rubber hose above the rear axle), and could hear bubbles coming from the tank, but it was extremely restricted. The line going to the canister also felt restricted, but not as much (and I could suck air through it, not gas). The line going to the vent didn't feel blocked at all.
So I first tried to swap the return and vent hoses, but after a few minutes the tank built up pressure and forced fuel out the vent (since the return line goes to the bottom of the tank).
So then I put a T fitting on the hose for the canister line, and connected the vent to that, and capped off the blocked return line to the tank.
So now my fuel pressure is normal, and there are no visible leaks. Please just let me know if I did something horribly wrong by hooking the canister hose and the vent to the same line coming out of the tank.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
TBRays98
Sep 6, 2015 05:05 PM
