Why? Why? Why? Someone please help
Old Mar 19, 2008 | 11:52 AM
kay15ace's Avatar
The car is a 1991 Camaro RS with the 305. A problem I am having is that my camaro Idles up and down sometimes and when I come to a stop sometimes it seems like it wants to cut off and sometimes actually does it, It has cut off twice on me in the past two weeks. Everytime I let off the gas and touch the brake I tremble in fear because of this problem I wonder is it going to cut off now or the next stop. Also when it rains outside really hard and I try to start it sometimes nothing happens. I'll just turn the key and nothing will happen. fifteen or twenty minutes later it will then fire up like nothing was ever wrong. I'm mentioning these two problems because I believe they are in correlation with something being wrong and I can't put my finger on it. Can somebody please tell me what could be wrong?
Old Mar 19, 2008 | 12:10 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
Re: Why? Why? Why? Someone please help
Sounds electrical, only because you said it really affects the car when its damp or rainy out
Old Mar 19, 2008 | 12:22 PM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Does it turn over or just not do anything?
Old Mar 19, 2008 | 12:23 PM
kay15ace's Avatar
It does not do anything.
Old Mar 19, 2008 | 12:35 PM
Car: 85 IROC-Z
Engine: 355 TPI
When it does the no start does the security light stay on? And as for the way it is running I would start with a tune up. plugs wires cap and rotor.
Old Mar 19, 2008 | 12:38 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Quick thought and I maybe wrong but it won’t cost you anything if it doesn’t need replacing. Checking the Distributor cap my guess because you said that when it’s raining. When it is that the moisture is get under it the engine well not start and the key well just turn with no effect.
Old Mar 19, 2008 | 01:37 PM
kay15ace's Avatar
Im not sure about the Security light I think it does I'm not sure but the SES light stays on.
Old Mar 19, 2008 | 02:36 PM
Car: 85 IROC-Z
Engine: 355 TPI
Well your car has the Pass Key II theft deterrent system and they tend to malfunction with age. If your system is not working right it will shut down the starter so it won't start. It will then reset itself in a few minutes and then you can try to start it again. There is a way to disable the system and the procedure is on this site. You might want to check it out.
Old Mar 19, 2008 | 02:57 PM
Stevo's Avatar
Car: Pair of 92 Z28s
SES light is on you said? All the time? Sometimes? When does it go on only at stoplights? Have that checked before you start throwing parts at it.
Also check your distributor cap, a lot of times when they are replaced only 1 screw is holding the cap because people cant reach the rear one so its not completely sealed. Condensation, moisture could be a colpret. Take it out and inspect for corrosion.
My gf's old RS 305TBI had the same problem it would stall sometimes in the rain. It was so random though that i could never find out what it was.
Old Mar 19, 2008 | 03:03 PM
kay15ace's Avatar
Well the SES light comes on when I switch the key to power/accesory and when I fire the car up it goes away. It comes back on it seems when Im driving between 45-60 for a short period of time but thats it.
Old Mar 19, 2008 | 03:28 PM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Under the driver side dash there is a plug, it's called the OBD, or ALDL plug, depending on who you ask. Either way, put a jumper between pins A and B.
Ignore the writing around that pic. It's not related to this.
It can be a paper clip, or a short piece of wire, whatever. Put it in with the key in the off position, and then turn the key on. Now, watch your service engine light. It's going to blink out sequences of numbers. To start off, it's going to blink 1 time, then twice. this is a "12". It's going to do this 3 times for each code stored in the computer. Code 12, is always there, it's to let you know you are now in "diagnostic" mode. After the code 12 flashes out 3 times, get ready to start counting. Write down what the sequences are that it flashes out. I got 5 bucks says you're going to get a code 32, which will be 3 blinks, followed by 2 blinks. Thats not what's causing your starting issues, but it is whats making the SES light come on after you've hit cruising speed.
After you get all the codes, turn off the key and remove the jumper from the OBD plug. Then compare them to this chart, and see what you got. Post back and lets us know what you found.
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 37 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 41 Ignition control error
DTC - 41 MEM-CAL error
DTC - 41 C³I Cam Sensor Signal error
DTC - 42 Ignition bypass circuit error
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
DTC - 45 Oxygen sensor error (rich condition indicated)
DTC - 45 Left bank O2 sensor error (rich condition indicated)
DTC - 46 Pass-Key II (VATS) system error - circuit out of freq range
DTC - 51 PROM error
DTC - 51 Incorrect MEM-CAL
DTC - 52 Fuel cal-pak incorrect or missing
DTC - 53 System voltage too high
DTC - 54 Fuel pump circuit low voltage
DTC - 55 ECM error
DTC - 58 Trans fluid temp sensor circuit error (low voltage)
DTC - 59 Trans fluid temp sensor circuit error (high voltage)
DTC - 61 A/C system performance
DTC - 63 Right bank O2 sensor circuit error
DTC - 63 MAP sensor circuit signal voltage high (low vacuum indicated)
DTC - 64 Right bank O2 sensor lean exhaust indicated
DTC - 64 MAP sensor circuit signal voltage low (high vacuum indicated)
DTC - 65 Right bank O2 sensor rich exhaust indicated
DTC - 66 A/C pressure sensor circuit error (low pressure indicated)
DTC - 67 A/C pressure sensor circuit error
DTC - 68 A/C clutch relay circuit error (shorted to ground)
DTC - 69 A/C clutch relay circuit error (open circuit indicated)
DTC - 70 A/C pressure sensor circuit error (high pressure indicated)
DTC - 71 A/C evaporator temp sensor circuit error (low temp indicated)
DTC - 72 VSS signal circuit error
DTC - 73 A/C evaporator temp sensor circuit error (high temp indicated)
DTC - 75 Digital EGR solenoid #1 circuit error
DTC - 76 Digital EGR solenoid #2 circuit error
DTC - 77 Digital EGR solenoid #3 circuit error
DTC - 79 Transmission fluid overtemp
DTC - 80 Transmission component slipping
DTC - 82 3x Crankshaft position sensor circuit error
DTC - 85 PROM error
DTC - 86 A/D error
DTC - 87 EEPROM error (flash memory error)
DTC - 90 TCC error
DTC - 93 Transmission pressure control solenoid circuit error
DTC - 96 Transmission system voltage low
DTC - 98 Invalid PCM program
DTC - 99 Invalid PCM program
Old Mar 19, 2008 | 04:19 PM
Jigga2142's Avatar
Car: 91' Camaro RS
Engine: 5.0 liter 305 tbi
Transmission: TH700R4
This was real helpful i found i had a 22, and a 24
Old Mar 19, 2008 | 05:23 PM
kay15ace's Avatar
Does anybody think that it could be the injectors themselves not injecting the fuel right or at a consistent rate?
I had to get those two things replaced too.
Old Mar 19, 2008 | 06:55 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Originally Posted by kay15ace
...it seems when Im driving between 45-60 for a short period of time but thats it.
sounds like the good old code 32.
really a no brainer, but check the batt terminals. i was having some wacky issues in my Blazer a few years back. give the positive cable a hairy eyeball, and it would shut down. a wire brush and about 45sec solved the problem. -Jim
Old Mar 19, 2008 | 07:00 PM
APO's Avatar
APO
I doubt it's VATS. That's usually only at start up.
Old Mar 19, 2008 | 07:26 PM
S105.7's Avatar
Engine: L98 & L03
...which sounds to me like a vaccum leak big enough to f-up the MAP readings at an idle. thus rpm surge as O2mv goes nuts chasing its tail.
Old Apr 21, 2008 | 11:51 AM
kay15ace's Avatar
So how do I find a vaccuum leak? because my car only does this after I drive a distance. This happened this weekend when me and this mechanic tried to look at my car. I had it off and when I started it up it did not act up and therefore he was clueless I even tried to drive it around the block and get it up to speed and it still did nothing. Later that night though when I got home from work the rough idleing started again.
Old Apr 27, 2008 | 03:24 AM
olds88's Avatar
I've had a very similar issue happen with my Caprice. For me it would die out at seemingly random times at any speed regardless of how long it had been running. It typically started back up instantly. Long story short, I had a bad ignition wire. When the wire experienced moisture it would arc and the vehicle would die out. I replaced it for $5 and haven't had the issue since. Others have said to check the distributor cap for condensation and I second this.
Old Apr 29, 2008 | 01:39 PM
kay15ace's Avatar
It's not the distributor cap that's causing my car to not start up in the rain. It's the Security System that came on some of the Third gens.
I'm still clueless as why my car still stalls on me. Me and my friend looked at the vacuum lines and they all looked fine.
