Time to start tuning
Old Mar 23, 2008 | 01:07 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
well im going in head first. got my '427 in the mail Friday, and my G1 is on order. i've got a few questions to ask though.
first, what is the PSI for the given flow of the TBI injectors? i've got 61#ers, and CFM-Tech's AFPR. im run 18psi or so, assuming the spring will let me. anyway, i want to know what the original pressure is so i can caluclate my BPW. i know there is an "ideal range" but there must be an exact psi that 61# happens at.
second, how do i get started on MAF. i read over most of the posts, but i didn't catch the jist of it. there's a patch i need right? what about PCM pinouts for the MAF?
Fast355, is it worth it to persue dual Knock sensors like you did, and which were you using on a 305? i think you stated that i will need late model 350s, correct?
as for the vehicle stats its as follows:
92 RS, 305.
T5, 2.73 rear end.
Edelbrock TES, 3" Cat, Dynomax Cat-Back.
TPI Fuel pump, 61# injectors, inj. spacer, ground TBI, 14" filter.
thats all the mods for now. im hoping the future holds a LT1 cam, Edelbrock intake, and mild 081s. sorry for the novel, im just excited to make my 305 a little more than a 170hp dog.
Old Mar 23, 2008 | 02:19 PM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Re: Time to start tuning
For the 61#ers the stock is 12 psi I belive so at 18 psi would be 100 BPW.
Old Mar 23, 2008 | 02:58 PM
S105.7's Avatar
Engine: L98 & L03
great, so i can start there. i guess 100lb/hr might be a bit much for my 305. oh well, at least i'll have direction when it comes time for a 350.
any thoughts on patches/pinouts for PSPS, AIR Converter, VATS, ect. i would like this to be 100%. everything needs to function like stock...only better now. for now, this car needs to be fully smog legal. i've got my Blazer when i want to go crazy.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
