RPM jolt, missing?
Old Apr 10, 2008 | 11:21 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
RPM jolt, missing?
so for awhile i have had a slight "miss" maybe 10-15 RPM jolt on the Tach on deceleration. So i knew i had some moisture in the dizzy so i took it all apart, cleaned it and sprayed some wirer dryer on it to keep the moisture out.
Well start it up and it got worse. Even backfired twice bad. Figured it was the wire dry. Drove it awhile and it calmed down but the "miss" is still there.
Cap and rotor only six months old and look good. Wires new and high quality. What else could it be? I know sometimes it has no upper rpm power (for what engine it is).
What is it? Module (but then i would get nothing)
Fuel pump?
Fuel filter?
But why at exactly 3200 rpm and not above or below?
Anyone have any idea?
Old Apr 11, 2008 | 04:40 PM
ryan91rs's Avatar
Transmission: 4L60
Re: RPM jolt, missing?
no one can help? just put on new cap/rotor all wires have spark at the dizzy. suggestions?
Old Apr 11, 2008 | 09:03 PM
ryan91rs's Avatar
Transmission: 4L60
just replaced the fuel filter and used sea foam to clean it out. help! anyone?
Old Apr 11, 2008 | 11:04 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
When you took it apart and cleaned it, did you remove the module? You HAVE to make sure the dialectric grease is on the metal backing plate on the module, and that the screws that hold it in place are tight. That is it's ground.
Also, you wouldn't happen to have another distributor to try, would you? Maybe a freinds? It couldn't hurt to check. Make sure your timing is set right too. Never really had a problem like that, but hopefully you can fix it! That would annoy me.
Old Apr 12, 2008 | 12:18 AM
ryan91rs's Avatar
Transmission: 4L60
well i started it in the dead of night b/c i knew it had to be something simple i was missing. Unplugger the hood light and saw an arch. Belive it or not it was between the AC delete pulley and the bolt for it.
So now i get to find out which wire is bad and why my newer 8mm wires went bad. Think i might just wrap them with a heat sheiuld or something to keep the rubbing down.
at least i found the problem!!!
thanks for the help
db057
Apr 28, 2019 07:45 AM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
