Spark advance problem
Old Apr 14, 2008 | 01:47 PM
honken's Avatar
Car: El camino 70 ss
Engine: corvette lt1 94
I have the 6395 ecm and the car died for me i .
I change in a new pick up and module and set taiming to zero and the enging
ran like crap i can hear that the taiming is retard ?
If i set it by the ear and its run fin but look with the timing lihgt its like 20 degrees before?
If i set it by zero with timing light and set main spark bias to zero in the prom its run better(9.84 degrees in prom).
whats wrong is the ecm burn or wath.
Old Apr 21, 2008 | 01:39 PM
NotAgain's Avatar
Re: Spark advance problem
Do you need to unplug and block your vacuum advance?
Old Apr 21, 2008 | 02:47 PM
honken's Avatar
My dist has no vacuum or advance at all, its the ecm that doing all the work.
Old Apr 21, 2008 | 03:03 PM
Uglybronco's Avatar
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
One of the four wires from the distributor has a connector you have to disconnect to set the timing. You may need to follow the wiring harness back around to near the AC system to find the disconnect. Oh & go for 10 or 12 degrees advanced.
Note: It is NOT one coming off the coil. That one is for your tachometer.
Old Apr 21, 2008 | 03:29 PM
honken's Avatar
I have set the timing with disconneted timing connetor.
The timing was alright before the car died.
Now it run like crap at 0 deg i think it the wiring or the ecm thats burn.
I want some values to test the cables from the ecm.
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
